Data Master can it damage ecm 87 Vet
Installed new TPS set correctly.
After using Data Master engine cranks and does not fire. Data Master loaded it up.
Any thoughts. Did It damage the ECM..
Data Master is more reliable then tuner pro and easier to use. I like tuner pro's dash boards but in 10 k it has rough idle
I am checking connections and am replacing the ECM as it is on warranty. It has an unusual odor to it that wasn't there when I installed it.
Thanks Cliff just read this explains the rough running
From the shop manual (10K mode):
• Closed loop timers are bypassed
• EST (spark) is advanced
• IAC will control engine idle to 1000 RPM ± 50 RPM
• On some engines, canister purge solenoid will be enabled
• P/N restrict functions will be disabled
This link is a good reminder on checking wires
Steve
I have been using Data Master for about 5 years I also use Tuner Pro.
I was just grasping at straws
Love my 87
Thanks I was trying to set tps with data master volts did not reg. Started engine up and in about 10 minutes of checking wires with engine running the engine loaded up and shut off. With new ECM still only cranks. Will track the problem down thanks
Steve
Love my 87
Steve
Love my 87
I use Tunerpro for burning chips. Prefer Datamaster for logging.
