DFI Gen 7 Backup
Old 10-24-2014, 06:42 PM
yedister
yedister's Avatar
Default DFI Gen 7 Backup
How do I download the tune in the ECM to my laptop and save it.
Old 10-25-2014, 02:23 AM
Cliff Harris
Cliff Harris's Avatar
Contact Accel and find out how to do it (if it's possible).
A lot depends on how the tune is stored in the ECM. If it's in an EPROM then you would have to remove it and use a PROM burner to extract the information.
If it's in an EEPROM then the system probably has the capability of doing the backup through the serial port.
Old 10-26-2014, 04:05 PM
yedister
yedister's Avatar
Thanks for your input but you are incorrect. The profile can be edited directly from the laptop when I connect it, no burner needed
Old 10-27-2014, 01:59 AM
Cliff Harris
I said the burner was needed ***IF*** the tune is stored in an EPROM.
I also said your software should be able to read it if it's stored in an EEPROM, which obviously is the case.
To DFI Gen 7 Backup
Quick Reply: DFI Gen 7 Backup
