87 TPS question feeling stupid
Old 10-25-2014, 09:55 PM
AJ123
AJ123's Avatar
Default 87 TPS question feeling stupid
Past feeling stupid changed tps and I can't get it to stop impeading the throttel . The retainer on the tps is rubbing on the screw .
This is the orgionsl tps a different throttle body. Have been using another tps for 6 months the same style . Do I need a different tps for this throttle body?
Steve
Old 10-25-2014, 11:55 PM
AJ123
AJ123's Avatar
Steve
ground off excess plastic will check in morning and see it that worked.
Old 10-26-2014, 01:02 PM
AJ123
AJ123's Avatar
Sanded down plastic shaft
Installed set to .54 without a problem. throttle and sensor not hanging up anymore
cranks won't start battery low charging
lots of time to play with it today
Old 02-28-2016, 10:18 AM
Scott0757
Scott0757's Avatar
Was curious as to any performance improvement you may have seen with the Throttle body change. Was it worth it?
To 87 TPS question feeling stupid
Quick Reply: 87 TPS question feeling stupid
