Problem with TunerPro RT and '93 scanning
Old 12-05-2014, 09:02 PM
8a8mfh
8a8mfh's Avatar
Default Problem with TunerPro RT and '93 scanning
I can't find the answer.
I've had Moates APU1 forever for my truck and was surprised/excited that it can be used on my '93.
So I tried to connect to do a quick scan in the driveway using the $DA2 mask. The problem is every 30-45 seconds or so the security light will flash and the scan freezes. Then 20+ seconds later it starts again. It does this over and over.
Anyone know what needs to be done to get this to work properly?
Old 12-09-2014, 08:58 AM
LT1_383
LT1_383's Avatar
It sounds like the CCM might be interfering with ALDL comms. There needs to be a silence CCM command in the adx file. On 93's the CCM is the bus master. Ask around and see if anyone has a good working file for Corvettes.
Old 12-10-2014, 05:45 PM
Z51breeder
Z51breeder's Avatar
Try using TTS Datamaster instead
To Problem with TunerPro RT and '93 scanning
Quick Reply: Problem with TunerPro RT and '93 scanning
