383 stroker need recommended vendor for chip
Have a lunati cam. Eagle rotating assembly, new 24 lb matched injectors, opened up intake system.
Runs good 3000-4500. But idle is poor and low rpm is not so good.
Dui distributor.
Timing is rock solid.
Who is best vendor for custom burn?
Dui distributor.
According to the calculations, at 90% duty cycle, it will support about 350HP. Isn't that a little small?
If you were in my area, I'd suggest dyno tuning with Hitech Motorsport. Maybe you can give them a call and see who they know in your area? Assuming it is FL.
350hp is fine for an 18 year old. :-)
Thanks I will call them. I was thinking they could burn it and I could put it in is that not how it works. Do you have to take your car to the guy that burns the chip?
They tune on a dyno. I took my car there. Give them a call and see if they will do it without the car there. Hard to data log and do it through the mail, so to speak
Flat tops - 2/4 valve relief - dome pistons? Compression 9, 10, gears?
TPI intake? Data logs? I would say you are leaning out from air volume. A base 383 would need 30lb Inj and a mandatory tune.
Cam lun 1012071k 256/262 .454/.468
Heads Stock al. 4 angle valve job
Compression 10/1
Flat dish pistons with valve relief
Eagle rotating assembly b13004l03053
Opened up TPI plenum and runners
Stock injectors right now.
Stock exhaust manifolds. EG passages welded shut and ground smooth on the inside. NO cat dual exh with straight through semi mufflers.
Just looking for a nice streetable engine that gives you a little kick in the pants when you push of the gas.
Educate me. Do not want max HP not going to change heads just want to take it from here and get it tuned.
I take it your suggesting finding a vendor that can put it up on their dyno and tune it at the same time. I would need to pick the right injectors and have them installed first though.
So I've been getting conflicting advice that is why I ended up with the 24lbs not installed yet.
Thanks for your help I appreciate it.
Merry Christmas
Compression 10/1
Merry Christmas
First off don't use stock injectors. Get the recommended size. Recommended by the programmer. He needs to know this. My 383 has 42 pph injectors. I know I will not run lean. Lean is BAD.
Find your tuner, ask him what you need for injectors, get them installed and send the car to him for tuning.
I prefer dyno tuning since it is hard to get the car on a track for tuning. Next best is to have them send you a tune, you datalog, send it to them, repeat till it is done. If they say they can write once and it is done, run like hell.
OK if I do that will the car still run??
I guess I should be asking him that question.
Right now I would say it is running rich at Idle and lean at cruise.
Well back to the original question with a Location Sarasota/Tampa. Anyone know of a good tuner is and around this neck of the woods?
Merry Christmas
Merry Christmas
I'm not sure how TPIS does it. I would be nervous about a tune that someone writes off the top of their head without making alterations. I don't think that they datalog but if they do, go for it. To me it is like getting a suit made off some spec without making sure everything fits. Find a company that will dyno tune in your area or one that does it datalogging.
Well Clay said they take all the information from the build then use their years of experience to burn the chip.
It is guarnteed and if it does not work they will burn another until it does.
My car is stick 4+3 so shift points are not a problem.
Definition of "work" and how you would know? If by work you mean drive decent and probably not at it's fullest and verified by the butt dyno, yes. Will you leave something on the table? I'd bet so. Why? Because if I were tuning it that way, I would not maximize it without it being in front of me. If you are accepting of that, fine.
I have a 700R4 and I don't think it is shift points that are the only issue. After all, I think my computer sends the lockup signal only.
Would a bridal dress be better that way or having a tailor fix the dress to suit the person?
You can modify the valve body to lockup in 4th gear. The ecm completes grounds. Grounds the injectors, fan relays, and TCC solenoids. The power comes from the brake switch that unlocks it when brakes are depressed.
