96 LT1 scan data
96 LT1 scan data
Hi all,
Vehicle is a 96LT1 (OBD II).
Aftermarket cam with related valve train parts and computor tune by PCM For Less. Everything else is stock except for muffler eliminators. Still has stock cats.
Cam card pic attached in PDF.
Scan data attached in PDF.
Scan data is 3 frames of cold idle, 3 frames of hot idle, 3 frames of cruise, 3 frames of WOT.
I've been working on a slight high idle issue that seems to have been improved by a TB cleaning. Take a look at my scan data if you have time and let me know if things look generally in order. If they don't look in order, what's your opinion on what's happening and what to do about it?
Scanner is Autel AutoLink AL519
Thanks.
Thanks.
