Simple question
Simple question
How many IAC steps should I add for when the A/C comes on?
I have zero steps added now and my RPMs drop by 100-200 RPMs for about 20 seconds when I turn the A/C on and then they go back up and stay at target. I want to get rid of the initial drop.
Thanks.
Thanks.
Check your IAC counts before you turn the air on and after is settles down after 20 seconds, the difference is what you add.
It increases the target RPM. Then the ECM increases the IAC count to attain that RPM. There is a tolerance on the RPM. My recollection is that it is 25 RPM, so it will get within 25 RPM of the target RPM.
