84 corvette bad hesitation tuned port converted
Old 03-19-2016, 06:21 PM
spivie
Cruising
spivie's Avatar
Default 84 corvette bad hesitation tuned port converted
i have an 84 corvette with mass airflow tuned port,painless wire harness new computer hypertech chip accel injectors dui ign. reads 45 psi of fuel pressure. it hesitates like i has no gas after the engine gets up to operating temp. i just changed the filter and pump with no change. not real familiar with this old injection system any info would be much appreciated. also the engine was overhauled and a performance cam was also put in have no idea what cam it has as all this work was done before i got it and the guy gave up on the project.
Old 03-19-2016, 10:20 PM
Cliff Harris
Cliff Harris's Avatar
Hesitation is usually caused by a vacuum leak. Too much air and not enough gas.
Old 03-19-2016, 10:47 PM
spivie
Cruising
spivie's Avatar
Already checked all that out no vacuum leaks
Old 03-20-2016, 05:34 PM
spivie
Cruising
spivie's Avatar
The ecm part number in the car is a reman 7 6870 and the hypertech chip is 115 41 what I could read off em the computer appears correct not sure about the chip
Old 03-21-2016, 12:48 AM
Cliff Harris
Are you REALLY SURE?
I have heard of vacuum leaks on the bottom of the intake manifold runners, for example. I had a leak at the rubber coupling between the PCV tube and the intake manifold. They can be very subtle and really hard to find.
Old 03-23-2016, 09:14 PM
Gibbles
Gibbles's Avatar
I had one drive me nuts related to the crank case vent...
Issue was that i installed a open vent on one side and then left the oem check valve vent on the other side for the evap...
Just saying it might be staring you right in the face like a fancy chrome breather...
Old 03-23-2016, 11:35 PM
Cliff Harris
I found out recently that the reason the air from the throttle body goes to the passenger side valve cover is that it is metered because it has gone through the MAF. The air goes from the PCV valve into the intake manifold so it affects the AFR. Using a fancy chrome breather vent creates a vacuum leak.
Old 03-24-2016, 03:29 PM
Hot Rod Roy
Hot Rod Roy's Avatar
a performance cam was also put in have no idea what cam it has.
Is the "performance" cam correct for an EFI engine? Cams designed for carbureted engines don't work well in EFI engines. Everything else can be perfect, but the engine still won't run well. What is your manifold vacuum at idle? Do you have a steady idle, and what is your idle speed?
Old 03-26-2016, 11:39 AM
MrWillys
MrWillys's Avatar
BLM (BLOCK LEARN MEMORY) is the ECM's ability to adjust for fuel. it runs from 108 to 160 with 128 being perfect. Counts above 128 is lean and below is rich. Also, base timing is 6 degrees. When adding a performance cam you should have 2 to 4 degrees added to the spark map in the idle area. Simply adding it to the base is a grave error. Find someone who can help you such as Alvin at PCM of north Carolina after you know your BLM counts at various points of operation.
To 84 corvette bad hesitation tuned port converted
Quick Reply: 84 corvette bad hesitation tuned port converted
