The Next Stage
The Next Stage
Hey all. About to kick off a swap to EBL Flash in my '84 Crossfire; I've done a lot of reading and feel I'm as prepared as I can be without actually "doing" the task...so I suppose my final step is to ask you folks for advice.
Crossfire-specific info would be most helpful, but I'd love to hear from any experienced voices, really. Pitfalls, pro-tips, anything you'd like to share about your project & process would be most appreciated!
Here's a link you might explore:
http://www.corvetteactioncenter.com/...ld-update.html
Let us know about your progress! Sounds like an interesting project!
84Z51J (04-07-2016)
I have read that thread & others of his, but thank you gleaned a lot of great info from his project. I may have more tweaking to do due to adding the head swap into the mix; hopefully the Vortec spark mapping will be a good starting point (heads are aluminum, but heart-chambered), blended with the TB4 starter BIN that came with EBL.
One thing I just realized is the need to add an IAT sensor--don't know how I missed it before! Got the sensor/pigtail/grommet on order; will measure when they arrive to see what size hole saw is required. Thinking I will do the cold air duct match cut at the radiator shroud & seal it as I've seen others here do, and find a spot near there for the IAT to avoid heat soak.
Ah, I was not aware of that, thanks for the heads up! Perhaps a couple of fine mesh dam guards could help abate the problem? Or...a slide-shut vent for rainy driving
