Fuse block power issue
Do not have power to either the inst. Fuse nor the fp fuse. I've checked that g125 is on and tight. Looking for g201. All the manual says is it is located behind i/p near lh side of steering column. Anyone know off and if this is behind the actual speedo/rpm guage or behind the info cluster?
https://www.corvetteforum.com/forums...post1589971933
What year is this car? G201 is at the "kick panel" on the left side, hinge pillar on inside. On some/most years you may need to remove the plastic sill cover to get at it. I would doubt that it's your issue but .......................
