Hyd. roller to Solid roller
Will I have any problems switching from a Hyd. roller cam to a Solid roller in a later model block. Will I still use the spider in the lifter valley with the solid roller? THANKS
St. Jude Donor '05
It's a pretty easy swap. Be sure to use the right lifers, you need the taller ones like the Crower 66290 for Bowtie blocks. The spider wont be used anymore. The solids will have a much improved technique/tie bar.
KM
KM
Cruise-In VII Veteran
I talked to Comp about this yesterday. Like 406 said, you won't use the spider. I was pleasantly surprised to hear that Comp had updated their line of lifters, with revised needle bearings and also high pressure oiling to the bearings. Part number 871-16 is supposed to be the correct lifter for the late model blocks - raised cross bar.
dont forget new springs and push rods.....not likely the same length with a solid lifter. If you want the best lifters go with the crower severe dutys or the crane pros.
