Need help injectors
Need help injectors
When I bought my 92 the previous owner told me he installed oversize injectors (how much over he does not know nor I ). But he did not change the chip. I was told that if you changed the injectors you must change the chip or you are defeating the purpose of the change out. It has a slight ruff idle, but you can smell it is running a little to rich and he said he lost about 2 MPG. I am thinking of going back to "new" OEM stock injectors. I just did a major tuneup this week so everything is fresh with OEM parts. Also changed out the waterpump due to leakage from weep hole, all OEM parts used there too.
Any help here would be greatly appreciated.
i would start by looking into the o2 sensers, do you have a scanner?? if not buy one you will save money knowing whats wrong rather spending money on parts that are not needed.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'd just put in an afpr to bring the fuel pressure down.
i have some 92 injectors laying around, I had flow problems with em, I was thinking if i found someone interested, i'd send them to be cleaned and tested on the way. otherwise, i'm not spending $90 or so to clean them to sit on my shelf.
