[Brake Booster] How to get new Brake Booster Screws into holes in firewall?
Any of you guru's here that have replaced a brake booster remember how you got the new brake booster into the proper holes in the firewall?
The square support brace that runs in front of the bake booster and above the battery is in my way, and I can't get it to line up. Any tips? If that stupid support was a quarter inch right or forward the new booster would go in without any trouble.
Is this a specific problem to late C4's?
I had the same problem with my 91. The support under the dash drops down just a little and it's a no go. I had the wifey push the booster into position while I pushed up on the support. After a bit of "higher, lower, dammits and oh s**t's" it all came together. Putting the nuts on the booster studs is whole nuther issue. A small magnet inside the socket or a bit of grease on the outside of the nut, anything to hold that puppy while you wiggle the extensions, swivels, ratchet and drop light into position. You might make a trip to the hardware store before hand to buy a couple of back up nuts, just in case. Somewhere inside the interior of mine lay 2 nuts, never to be found.
A little patence, a little luck and some perseverance it'll all work.
Good luck
Subman
Good luck
Subman
A mechanic friend came over, and really helped me out. He got the bar out of the way, I hadn't realized you could unbolt it, we got the new brake booster on it, and everything else bolted back together.
Now I just have to get the brake booster bar connected straight onto the bake pedal. Its sitting on there, just somewhat at an angle, so I can't put the clip back on there. I've unbolted it somewhat, but just can't get it over. I can't move a hammer enough to really get a good tap on it, but other than that I am done!
In hindsight, the clip should have been put on while the booster was still unbolted, and now I'm scared of unbolting it all the way!
Once a brake booster is malfuctioning, and the brakes start requiring 2 feet to press, can you repair it or would you have to completely replace the whole entire unit and bleed the brakes??
I believe it can be repaired, but its not something I would like to undertake. You don't have to bleed the brakes, but you do have to pull the master cylinder forward.
I paid a little over $100 for mine, exchange.
I've seen metal boosters (that don't split from being exposed to the exhaust/header heat) for about $175 in one of the catalogs. Ecklers, Mid-America or Corvette Central, forgot which.
Jake
Jake
