1995 OBD question
1995 OBD question
I understand that the 1995 model was a mix of OBD1 and OBD2. My question is... I found a good deal on a OBD2 scan / software tool. Says it will work on ANY make OBD2 vehicle. Will it work on a 1995 corvette. If not, what is a reasonable scanner that I can get that will run BOTH OBD1 and OBD2 (I have 1989 and 1995n Vette).
THANKS!
THANKS!
Check this thread http://forums.corvetteforum.com/show....php?t=1034505.
A 95 is obd1 with a obd2 connector under the dash. You don't need an obd2 scanner. Yet...
