Fuel lines - replacement
Old 04-03-2005, 11:05 AM
bheston
bheston's Avatar
Default Fuel lines - replacement
I was working on the vert and noticed that the aluminum fuel lines in the frame by the tank were slightly crushed. My guess it is from a floor jack. Has anyone seen this or replaced those lines? They look to run from the tank to the fuel filter/engine.
Old 04-03-2005, 11:41 AM
Pete K
Pete K's Avatar
These lines have been discontinued from gm for a while. To my knowledge no one is reproducing them. They can be repaired by splicing new sections in using unions. Another option, although expensive, is to run braided steel line as a replacement.
Old 04-03-2005, 03:58 PM
bheston
bheston's Avatar
GM Parts Direct had them listed and gave a price for each of about $80. Do you suppose I'll get a call after I order telling me they have been discontinued?
Old 04-03-2005, 04:32 PM
Mo_Bandy
Mo_Bandy's Avatar
I replaced mine with steel braded lines. I went to alocal "hose" placeo ge mine, but you can also get them through Summit, I also had my fuel rail welded with AN6 fittings... It is easiest to di it at the unions right at the frame rail.
Mo
Old 04-03-2005, 06:02 PM
Pete K
Pete K's Avatar
I suppose you will get a call. If not my parts guy was wrong, or too lazy to do a search. Keep us posted if they are available. Your question/ problem comes up quite often.
Old 04-04-2005, 07:46 PM
bheston
bheston's Avatar
Update - My local GM dealer ordered both the feed line and the return line for me. The application is a 92 LT1. They were $62 each. The part numbers are:
10158027 - Pipe, Feed line
10158028 - Pipe, Return line
These are from the tank to the filter/engine. They will give me a call when the parts arrive. Having said that, there is still no guarantee I won't get the "discontinued" call later this week.
Old 04-05-2005, 12:15 AM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Old 04-09-2005, 01:31 PM
bheston
bheston's Avatar
Default New update
Dealer called to tell me the hoses were in! Picked them up Friday and they looked perfect. All the bends, all the spring wire, everything(even the crimped on-rubber ends that go to the fuel pump). Evidently these are not discontinued or GM is making them again.
Now, I just have to install them!
Old 04-10-2005, 06:49 PM
bheston
bheston's Avatar
So I started the task of replacing the lines. Here are the minor things I removed:
- Gas cap door and rubber
- Right rear tire
- Spare tire
- Spare tire carrier
So I can see the line I just don't know how I am going to replace them without removing the exhaust and the rear end. They must have been installed at the factory before the rear end. I'm having doubts if this task can be accomplished without a major disassembly. Any thoughts?
Old 04-11-2005, 01:44 AM
Mo_Bandy
Mo_Bandy's Avatar
Bummer I thought you were just getting the front lines leading to engine from the fuel filter which have unions to make the install easier...
Mo
Old 04-11-2005, 07:21 AM
KAZ2
KAZ2's Avatar
Not what you want to hear, but, I would put my fuel pressure guage on and see if pressure was up to spec. If not, I would splice in a patch of the crushed section. I would put my new line which will be worth its weight in gold sooner or later in storage and save it for a restoration. I have heard of some fuel lines being rusted which would make it a no vote decision. I have the lines from the filter forward tucked away hoping I will never need them. Regards
To Fuel lines - replacement
Quick Reply: Fuel lines - replacement
