Engine hesitation on 84 C4
Old 04-15-2005, 11:28 PM
jtferris
Cruising
jtferris's Avatar
Default Engine hesitation on 84 C4
Ive got a hesitation coming off idle on my 1984 Corvette. I've been checking for vacuum leaks and other causes. Any suggestions on where to start?
Old 04-16-2005, 08:44 AM
DRAKEFAMILY2
DRAKEFAMILY2's Avatar
You might start with a tune up, plugs, wires, cap, fuel filter.
Old 04-16-2005, 12:41 PM
CFI-EFI
CFI-EFI's Avatar
I'd start by looking for vacuum leaks and other causes. A prime source of a vacuum leak is between the intake manifold lid and the base. Is the TPS properly set and operating smoothly? Does the MAP check out? How about the timing? There's a start.
RACE ON!!!
Old 04-18-2005, 12:37 AM
jtferris
Cruising
jtferris's Avatar
Here's the things I've done so far:
New Plugs
changed most vacuum hoses (getting about 20 in vacuum now)
set timing (but maybe not correctly) which wire do I pull before setting the timing to 6 degreees BTC? how do I identify it?
Fresh oil, oil filter, air filter.
throttle plates eem to open at the same time.
The hesitation is just off idle, almost kills the motor.
Old 04-18-2005, 09:33 AM
elkabong
elkabong's Avatar
The wire is near the power brake booster and the connector is black and the wire is brown with a black stripe. Also check your fuel filter and pressure.
To Engine hesitation on 84 C4
Quick Reply: Engine hesitation on 84 C4
