J55 Brake upgrade for 87 Vette
I don't want to be a deek but I would like to hear from someone whose actually done it. Went Autox today the front brakes in my 87 suck.
Don't have the time, money or inclination to go to C5 upgrade. Don't want to spend $1000 on a kit., don't want to change my wheels. My Enkie 9.5 wheels should work fine with the 13 inch J55 brakes and rotors.
I think I need
2- 88 whatever J55 calipers
2- 88 Brackets
2- new brake hoses (seems 87 and 88 have 2 different part numbers)
Any help out there?
Billy
I think I need
2- 88 Brackets
Any help out there?
Billy
Originally Posted by OleDog
I think I need
2- 88 Brackets
2- 88 Brackets
Both the C5 upgrade and the J55 upgrade has to have the "custom" adapter bracket to make the caliper bracket fit on your steering knuckle.
-Tom
Received 1,400 Likes
You dont need different brake hoses, you get the hoses for YOUR year.
I run the standard 11.5" front rotors on my 87 for autocross and track days. I usually run EBC Greenstuff pads (Tire Rack has them) for autocross and street and for track days, I use Hawk HP+ pads in front (also from Tire Rack).
I have not had any issues so far and braking performance is very good. The EBC pads have excellent cold bite and even when hot they haul the car down quickly. These pads show very little dust compared to the Hawk HP series. The HP+ pads are a bit noisy for the street and very dusty. Another good pad is the Performance Friction Z pad and they should be available through AutoZone.
For rotors, I buy the cheap "white box" rotors and just toss them when they show wear or excessive grooving. I use Earls' stainless hoses and run Ford MotorCraft heavy duty fluid which has a very good wet boiling point for autocross and track day use. I have Speed Bleeders installed on the calipers and bleed the brakes before every track day.
IMHO, it boils down to selecting the correct parts to make the factory brakes work. Stock pads may be OK for street, but if you do any performace driving, then the cheapest way to get good performance from the stock system is a good high performance pad and a good quality DOT4 brake fluid.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Originally Posted by tommelton
That is a good deal for the parts! Then you still need the adapter brackets...
-Tom
-Tom
Here's a shot showing the difference.
Originally Posted by BrianCunningham
See if you can get them from a salvage yard. Brackets don't where out.
-Tom
Thanks Again
Billy
