FAN RELAY DIAGRAM 86 & 89
Is the fan relay diagram the same on an 86 & 89. I having a chip burned for my 86 and I want to eliminate the cold start injector (9 injector) , the tech said that a 89 chip did not have the cold start and that it could be used in an 86 ecu, sometime the fans don't work properly, and you have to either get a fan switch or change the the terminal clips at the computer. Do any have a diagram for this?
Randy
Randy
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I'm not sure what it has to do with the cold start injector, but check my Tech Tip I posted for the fan relay diagram
This is for my 85.
http://forums.corvetteforum.com/show....php?t=1090392
This is for my 85.
