Which A/N fitting for stock fuel filter?
I need to exchange the stock fuel lines of my wifes '85 C4 to PTFE-lines. As I'd like to keep the stock fuel filter, i am wondering which fittings/adaptors to buy ... the thread on the filter is M16x1.5.
Unfortunately we already tossed the old lines so I can't take a look how they are sealing at teh filter. If I buy an adaptor AN-6 to M16x1.5 the only "gasket" is the thread itself what can not be good I believe.
Are there special fittings with an o-ring on the market? How did you guys deal with that?
Best wishes
Eike
Best wishes
Eike
Best wishes
Eike
Best wishes
Eike
http://www.summitracing.com/parts/sum-220009/overview/
I'll post back with some "singles" information from likely a different source. These were "quick"!
Here's some Paragon application charts and you might be able to use this information to create some search terms that could help you with your location. Russell should also do them. Here in the US it's quite easy!
http://www.paragonperformance.com/ADPTRS6.html
The ones you want are generally advertised for power steering and hydraulic uses. You need to be sure it's pictured with an o-ring and NOT just an M16 X 1.5 to AN-6. The o-ring might also be dimensionally different for the hydraulics and I've never attempted to check the fit in a fuel filter.
