Hardtop Headliner repair
Old 08-03-2005, 07:49 AM
LD85
LD85's Avatar
Default Hardtop Headliner repair
Hey guys, any suggestions on doing a head liner repair. I only see one post when I do a "search"
Where do you get a dense foam and headliner material like or similar to the OE and who sells the "heads up adhesive for the headliner?
TIA
Old 08-03-2005, 07:54 AM
onedef92
onedef92's Avatar
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can check online at Mid-America Motorworks (MAM) I believe they carry replacement headliners.
Old 08-03-2005, 08:31 AM
nitronick
nitronick's Avatar
Check your local listings for an upholstery supply. They should have everything you need. I would bet it is a whole lot cheaper than buying a new one.
Old 08-03-2005, 10:02 AM
LD85
LD85's Avatar
Will do!
Old 08-21-2005, 12:28 PM
LD85
LD85's Avatar
OK, I now have the head liner material for my 1985 Hard top
I pulled the old black stuff off fabric off, and rubbed off all of the foam stuff from the sound deadening cushion.
I tried to peel back some of the sound deadening insulation material but I dont see anything under it, is this material glued to the hardtop bottom side?
Anyone done this, do I pull the sound deading material off? Do I have to buy the new insulation too?
Old 08-21-2005, 12:58 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
That backer board will come right off if you pry under it with a putty knife
Old 08-21-2005, 01:24 PM
LD85
LD85's Avatar
Thanks, mine does not appear to have a backer board but I will check again
Old 08-21-2005, 02:09 PM
Cruisinfanatic
The sound deadening material that you refer to is the backer board.
Old 08-21-2005, 04:03 PM
LD85
LD85's Avatar
Gotcha, I just pulled it off a few minutes ago,,,and I'm scraping the small amount of adhesive off of the fiberglass.
Looks pretty simple except the headliner material I bought has foam on it and it is a little thicker than the OEM material.
Is this the same type of material you used, meaning a foam back headliner?
Joslinm, thanks for the help, I probably should take some digital pics for the future.
Old 08-21-2005, 05:44 PM
LD85
LD85's Avatar
Done, probably a 1-1-1/2 hour job, thanks for your help again Joslinm!
Yes the backing is attatched to the sound deadening material, scrape it all off slowly with a putty knife and then wrap it with new headliner material after allpying adhesive.
Scrape all of the left overs from the fiberglass with a razor blade, clean it well,,,then spray it with adhesive.
Buy Headliner adhesive at Autozone for @ $8-9 bucks.
Simple job!
Old 08-22-2005, 01:19 AM
Rick86
Rick86's Avatar
recently reupholstered my hardtop, I found the spray adhesive I used to glue the headliner to the foam pad did not work well for holding the pad to the roof. I used 3M weatherstrip adhesive and it has been holding fine. I have a black top and the car sets in 100* weather all day while I'm at work and so far so good.
Old 08-22-2005, 03:04 AM
steve40th
steve40th's Avatar
St. Jude Donor '03 & '05
I had my headliner in my 93 done in Leather. Mucho Better.
Old 08-22-2005, 08:39 AM
LD85
LD85's Avatar
I bougth Headliner adhesive, I hope it works, time will tell! I cleaned the fiberglass really well, so maybe this will help!
Old 08-22-2005, 09:03 AM
rrubel
rrubel's Avatar
I used "Heads Up!" to hold my new fabric up and it's held for a couple years now. The 3M stuff I used first didn't last a week.
[RICHR]
To Hardtop Headliner repair
Quick Reply: Hardtop Headliner repair
