Bars Radiator Stop Leak...safe for the vette?
yes, there is, and its the bars leak tablet or powdered stuff
organic mainly, no metals or solvents,
but only use the powder or powder pellets.
Works great, GM recommended for many cars in the past,
anyone remember the caddy HT-4100 4.1 v8?
1 Post
St. Jude Donor '05
Put some in my vette for preventative. No problems.
It was also recommended in the book, "101 Projects for Your Corvette 1984 - 1996" by Richard Newton i
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
If you really need an emergency, limp-home fix, pour a can of ground black pepper in your radiator.
No SHET! It'll fix the leak long enough for you to flatbed it home or to a garage and will easily flush out when it's time to.
Cruising
I know. It's an old thread. I have used Bars Leak for years with no problems. It's in my 63 and my 94. The 94 came from the factory with it in the cooling system. Suzuki requires it in their motorcycle engines. The Navy used it in the Nautilus.
"Wade A. from North Carolina has a keen eye while reading: in the book “Nautilus 90 North,” he noticed that the stop leak Commander Anderson used in the 1958 Nautilus submarine voyage under the Arctic ice cap was the same stuff you can buy in stores for your car.
Yes, you read that right: Bar’s Leaks was used successfully in a historic nuclear submarine voyage under the North Pole ice."
P.S. This thread isn't just old, it downright decrepit. Zombie threads - gotta love 'em.
If it needed stop leak, it sounds like the cooling system wasn't built properly.
Only if you are driving the USS Nautilus and not the Nautilus from 20000 leagues under the sea.
Cruising
Back when I was racing Alpha Romeos we always put one pint of Bars leak in the engine to prevent electrolysis. The Alphas had aluminum engines with copper radiators.
Coolant supplement
Original owner of 1996 Corvette LT4. I have changed my 96's coolant every 5 years like the owners manual says and also every time I added the supplement as per the owners manual
When I have changed the coolant I drain radiator and remove both knock sensors to get a complete drain of coolant every 5 years.
Will do it again in 2016. I don't flush, just drain the system and use distilled water with original type anti-freeze.
It's in the book "Nautilus 90 North" The leak was in the nuclear reactor. The fix would have required cutting a hole in the pressure hull. The Bars Leak remained in the system until she was decommissioned in 1980.
Did anyone test for electrolysis and verify that it does exist before dumping in the stuff? How is it different than changing out the coolant BEFORE it wears out? Mercedes recommends a coolant change every 3 years. To most people, a flush just means drain radiator and add coolant. I drain the block and flush the holes on each side (remove KS on passenger side and coolant hose to oil cooler on driver side), I also activate the heater to make sure the valves are open. I drive for a few miles and drain the block again and flush again.
