700R4 Vette 5200 WOT Shift Governor?
I see advertised a 700R4 Corvette WOT 5200 Shift Governor. What is the difference between this governor and the 'regular' 700R4 governor? Weights? Plastic Gear?
Reason being I have a rebuilt tranny and it don't shift like the original used to. The 3-4 upshift occurs at 37 mph. Would like to make it like the original tranny where it shifted more towards the mid 40's mph.
Will swapping out governors do the trick - assuming they did not use a corvette governor in my rebuilt one?
Or do I just need to play with the weights and springs on the stock governor?
Cruise-In II Veteran
It sounds like you need to adjust the TV cable as that is what governs part throttle shift points and shift feel.
The governor only governs WOT shifts; you can buy a B&M Governor Recalibration Kit from Summit to modify the WOT shift points. This is done by changing the small weights & springs within the governor.
http://www.transmissioncenter.net/700r4.htm
#6. Do not attempt to adjust the shift timing with the throttle valve cable. The shift timing is controlled by the governor springs. For higher shift points at wide-open throttle, install lighter springs. For lower shift points at wide-open throttle, install stronger springs.
I got one of these 700R4 Vette governors and the only thing I see from the picture is that the gear is blue rather than white as on the original. It looks like the same number of teeth from the picture.
I will have to pull the one in there now and compare the weights and springs. I guess the right thing to do is to:
1. Pull the original
2. Stick in the vette one - note the difference.
3. If it still is not the same, change the weights and the springs, one step at a time.
Looking at the manual it says to pull the exhaust and x-brace. I hope I don't have to do that - it would be a real PITA, especially if I need to change springs and weights a lot of times thru trial and error.
I wish I had a lift
I wish I had a lift
I wish I had a lift
I wish I had a lift
RACE ON!!!
I made 3 attempt to fine tune my WOT shift points (I raised it..with the B&M recalibration kit changing only the weights...)
Part throttle shift points changed too, expecially the 3 to 4 shift delayed up to 20 mph!
-Beppe-
