Oil filter size/thoughts/opinions (and cooler Q)
I have an oil filter size question, more out of curiousity. I got 4 vehicles with SBC(small block chevy) v8's and I thought could fit the same filter on all of them...'till I got under the LT4 and there is this little tiny filter on it and a special adapter to the block for this small filter.
I like to run a larger filter just for the extra capacity, its probably completely unnecessary, but its the 'male' thing to do. And now, with my LT4, I suffer from "Oil Filter Envy".
Anyway, seriously, are there alot of different vette oil filter sizes for the C4 or just a couple? The only real clearance issue on my car is the cats are huge and in the way, and since all C4's at least -had- cats when new, I wonder if the size and placement has changed over the years. I have a friend with a 91 and he says the normal SBC filter fits on that.
My LT4 filter is( I hope the cross refences are correct):
Purolator (P)L24011
Fram PH3980
AC PF52
MotorcraftFL402
Wix 51036
Fleetguard LF3554
The size I typically run is:
Purolator (P)L34631 ( PER4000 equivalant? I cross referenced to AC delcos site for this)
Fram ?
AC PF1218
Motorcraft FL12FP
Wix 3
Fleetguard ?
The older size appears to be(and this references to many SBC cars):
Purolator (P)L20049
Fram PH30
AC PF25
Motorcraft FL10
Wix 51069
Fleetguard ?
After further research, it seems 1992 is the crossover year. I'm guessing a catalyst design change caused this.
I'm not real concerned or anything, but I just thought I'd fish for opinions. The larger converter will make it more challenging for me to add an oil cooler if I decide to, but I could just go remote filter at the same time and it shouldn't be too bad.
I know there are a million thoughts on oil filters, I like Purolators Pure One's because of the silicone antidrainback valve and their filtering reputation is pretty good too.
For track use, are oil coolers highly recommended? This is "hot lap" use, not "competition" use.
I would ask to see if anyone found a larger filter for the (apparrently) '92-'96 SBC vettes, but I don't think there is any more room, and it already hangs down to about the bottom of the oil pan.
thanx for any thoughts on this,
and I hope I'm not
»keith
Purolator (P)L24011
Fram PH3980
AC PF52
MotorcraftFL402
Wix 51036
Fleetguard LF3554
Fram ?
AC PF1218
Motorcraft FL12FP
Wix 3
Fleetguard ?
Purolator (P)L20049
Fram PH30
AC PF25
Motorcraft FL10
Wix 51069
Fleetguard ?
and I hope I'm not
»keith
»keith
»keith
I'm not sure of the benefits of the new 'smaller' AC oil filter is there one?
Dave
Originally Posted by Davemc1963-87conv
I don't believe the antidrainback function on a SBC is worth much, due to the fact that the filter is upside down and can't physically drain back anyway.
If anything, IMO, if it were to malfunction (not very likely, but possible) it could provide a restriction to oil flow. However most filters seem to incorporate them these days in one form or another.
It could be that I just like the Pure One cause of its dark blue metallic paint and chrome sticker.
Dave
Dave
»keith
I use a Bosch 3430 on my 94. It is about one inch longer than the stock filter, same diameter. Any fatter and it wouldn't fit, any longer and it could smack something on the road.
Originally Posted by Hotred94
I use a Bosch 3430 on my 94. It is about one inch longer than the stock filter...
A buddy of mine who had a 305 cid pickup truck used to run "farm rated" oil and he also found these 99 cent "defense" oil filters that were near 10 inches long!(give or take). I think he thought his little truck was a semi or something. I never did try to look up a cross reference for that filter cause I owned cars which are too close to the ground for a big filter like that, but I did think about trying them out once.
»keith
