LT4 top speed in each gear - can't find
with stock 3.45 rear my experience gives me a +/- 2mph error
this is revlimited in each gear
1st - 51mph
2nd - 75mph
3rd - 100mph
4th- around 130mph
5th - limited by horsepower and wind resistance
1st - 51mph
2nd - 75mph
3rd - 100mph
4th- around 130mph
Thanks,
I think what I saw was a scanned road test of a Grand Sport by C&D or R&T that had the specs.
Pretty close to what you posted.
I'd like to be able to remember where that link was. Maybe not still up.
Originally Posted by Shaun R
1-55ish
2-80
3-108 thats what I trap at the track crossing the finish on the revlimiter
4-135ish
5-170ish, but havent seen it.
2-80
4-135ish
i am confused with your gear number three. -
i revlimited in third for half a sec coming to the line and the track said i did 102.5. then next try i went into fourth and pulled 104.5 - but my spedo said 105 the first and 107 the second.
this was after having my car for one month. though i pulled a 13.527 at 102.2 but this was when my opti would miss underload and you could feel the throttle pulse
weird?
dont know how i pulled three 13.6's at 104.1-.6 and my 13.5 at 102.2
PPL have always commented on how my car stays in gear for a long time, but its not enough where I think the previous owner did anything w/ the final drive ratio. That was on 285/40-17's, dunno on 275/40-17's
1st - 51mph
2nd - 75mph
3rd - 100mph
4th- around 130mph
1st - 51mph
2nd - 75mph
3rd - 100mph
4th- around 130mph
I have a 383 and I pull 113mph on the limiter, but that is at around 6800rpm, so 107-109 is about right for the stocker, pulled 191mph in 5th almost on the limiter, like 6600rpm, that was flying.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Originally Posted by froggy47
Thanks,
I've got that issue of CandD at home. If the speeds are significantly different than what Birdman and Shaun posted, I'll post the CandD results when I get home. I do remember that the GS would not pull redline in fifth gear, but topped out at something like 5500 at 169mph.
Larry
code5coupe
RPM 1st 2nd 3rd 4th 5th
1000 07 12 16 22 32
2000 15 25 31 45 63
3000 22 37 47 67 95
4000 29 50 63 90 126
5000 36 62 78 112 158
6000 44 75 94 134 189
6100 44 76 96 137 192
6200 45 77 97 139 196
6300 46 78 99 141 199
6400 47 80 100 143 202
I wasent that far off, but again. I dunno why I trap 7-8mph higher than that. That was done w/ a 285/40-17 tire, stock zr6 ratios and a 3.45 rear gear. See for yourself.
1000 07 12 16 22 32
2000 15 25 31 45 63
3000 22 37 47 67 95
Did that wrong, these numbers are using the ratios off the zfdoc.com.
6300 53 78 109 141 188 282
6400 53 80 111 143 191 287
Again same setup tire and rear end size, only using the ratios below.
Gear ratios - 1st-2.68, 2nd-1.80, 3rd-1.29, 4th-1.0, 5th-0.75, 6th-0.50, Reverse-2.50
I concur with high 120's in 4th gear. and I have no idea how anyone gets the car over 140. I tried at Pocono, and once I'm in 5th, the increase in speed in very slow.
this is all my personal track experience, not magazine data.
froggy: If you want theoretical topspeed in each gear...just punch up the numbers in a gear calculator...this doesn't mean your car will hit these speeds!
Gear Calculator
For quarter mile mph...remember the speed is calculated as an average of the last section of track-not instant mph speed.
Stock I knew it was a good run when I was on the limiter in third as well...with a best of 110 mph (6400 rpm on OEM LT4-no it never blew up!)
Gear Calculator
