Autometer Speedo hook-up w/ LT1
Old 02-03-2006, 05:21 PM
DR'76
DR'76's Avatar
Default Autometer Speedo hook-up w/ LT1
I'm having problems with an Autometer Speedo (Phantom series, 5889) that I have installed in my '95LT1 / 4L60e powered '76 Vette.
Here is an e-mail I just sent to Autometer, but being that it's now Friday night, I don't expect to get a response until at least Monday...maybe others can help?
>> I'm using your Phantom series Electronic Speedo (5889) in a vehicle utilizing a '95 LT1 engine / 4L60e transmission (automatic, 4-speed) w/ a '95 F-body (Camaro / Firebird) PCM...
Per the instructions provided, I spliced into the VSS circuit (coming FROM the VSS - circuit A32, yellow wire) and connected into "Sig", then from "Out" connected back into the VSS wire going TO the PCM. After calibration, this worked for a few miles, then the transmission started shifting improperly (wouldn't come out of 1st, wasn't in the correct gear even if shifted manually, etc.) I bypassed the speedometer and connected the spliced wires from the VSS back to the PCM, but that didn't resolve the shifting problem. I ended-up having to replace 2 shift solenoids in the transmission before things were back to normal. Not knowing if that solenoid incident was caused by a problem w/ the speedometer or just a coincidence that it happened shortly after hooking up the speedometer, I just tried the connections again and same thing...no shifting out of first. I immediately stopped to avoid further damage and bypassed the speedometer again (all is OK w/ the transmission), but would REALLY like to have the speedometer functional.
I also have a "VSS OUTPUT" signal (circuit B8, green/white wire, in the F-Body PCM) and I tried connecting that TO "Sig", but get no response from the speedometer.
Connecting to either "VSS" or "VSS OUTPUT," the speedometer correctly goes thru it's calibration process (goes to MAX when holding reset button while starting, then goes to MIDPOINT when pressed again to start the 2-mile drive, then to ZERO when pressed @ the completion of the 2-mile drive), then no further response is seen.
Is there something I'm not doing correctly here?
Hopefully I provided enough detail...PLEASE let me know if any additional information is needed.
Thanks for your assistance...have a GREAT weekend.<<
I know others have installed these into their C4's or LT1 powered C3's (VetteDan, I PM'ed you w/ same info)...any ideas???
Thanks!
Old 02-03-2006, 06:47 PM
CFI-EFI
CFI-EFI's Avatar
For what it's worth, if anything, 4L60E equipped C4s get their VSS signal from a wheel reluctor, not the trans. You may have better luck on an F body forum.
RACE ON!!!
Old 02-04-2006, 03:55 AM
DR'76
DR'76's Avatar
OK, I'll try over at thirdgen.org...
Thanks.
Old 02-04-2006, 04:54 AM
ninetyfivevette
ninetyfivevette's Avatar
Thanks.
Let us know what you find... I am sure more than just a few would love to ditch their stock cluster for a suite of Autometer analog gauges. I know I would.
Old 02-04-2006, 09:52 AM
-=Jeff=-
-=Jeff=-'s Avatar
With the reluctor wheel I believe there is a converter box (converts the Reluctor signal to the VSS ssignal we need.
My buddy when is he swapped in a 4L60E into a 90 Corvette had this issue if I remember right. Also Autometer may sell such a converter.
As for Autometer gauges in a C4..
I know.. BAD Photoshop.. LOL
Old 02-04-2006, 10:54 AM
FD2BLK
FD2BLK's Avatar
I would normaly think that the speedo was having a problem with the pps rate of the VSS but the fact you had it working to begin with proves it is fine. From what you are describing I would either suspect a bad reluctor ring or a bad Speedo. I would contact Auto meter and make sure you did not need a load resistor of some sort to feed the speedo as to not load down the VSS signal then I would ask them how you can check it.
Old 02-04-2006, 02:31 PM
DR'76
DR'76's Avatar
CFI-EFI - wasn't sure what you meant by that. The 4L60e DOES have a VSS that is part of the transmission and feeds the info to the PCM thru circuit "A32" in the "RED" connector (See SM, page 7A-25, fig. 23). That is the wire I cut and connected to the "Sig" terminal in the speedo, then from the "out" terminal of the speedo (supplies a "buffered" signal) back to the PCM. If you could further clarify..??? (Thanks!)
-=Jeff=- not bad w/ the Photoshop (better than I could do!), but AutoMeters look pretty cool in the C4 layout. I had to relocate my directionals, hi-beam and brake warning lamps as well...
I'm still waiting on a response from Autometer (I'm sure it will be after the weekend), BUT I did contact them PRIOR to purchasing and they said would be "fine"
Old 02-04-2006, 05:50 PM
CFI-EFI
CFI-EFI's Avatar
CFI-EFI - wasn't sure what you meant by that. The 4L60e DOES have a VSS that is part of the transmission and feeds the info to the PCM thru circuit "A32" in the "RED" connector (See SM, page 7A-25, fig. 23).If you could further clarify..??? (Thanks!)
I don't have a service manual (SM?) that covers a car with a 4L60E transmission. Your page and figure numbers don't help us communicate. Are you sure that VSS is for speedo display and not for other ECM, PCM or other ??M functions? I simply consulted the Corvette Forum Speedo Gear Chart for my information.. Maybe I spoke out of turn. I'm sorry if I caused any confusion or problems.
RACE ON!!!
Old 02-04-2006, 07:13 PM
Hooked on Vettes
Hooked on Vettes's Avatar
You say you spliced into the wire. Don't you mean you cut the wire? Instead of cutting the VSS signal yellow wire I would think you would just need to tap/splice into the wire which would provide the VSS signal to the Autometer Speedometer input. The VSS signal wire to the PCM would remain unchanged. (Not use the Autometer speedometer OUT signal back to the PCM).
Old 02-05-2006, 10:46 AM
DR'76
DR'76's Avatar
CFI-EFI: That's where there's still a little confusion. I have a "VSS" wire and a "VSS OUTPUT" wire. Prior to installing the electronic speedo, the VSS OUTPUT wire was unused. This wire comes FROM the PCM. I originally hooked the speedo up to that wire, but had no response from the speedo. I then cut the VSS wire and connected that to the speedo, then from the speedo's "out" terminal, back to the PCM...then the speedo worked, but soon gave me shifting problems (I guess the signal got "distorted" or wasn't "clean' anymore????)
(Sorry about the acronyms...they drive me nuts too )
HOOKED: yeah I should have said "CUT", but see what you are saying...I should just tap/splice into ("T" into) the VSS signal, which should still provide a clean signal to the PCM and give a signal to the Speedo to work from. I don't think I tried that, but if so, will try it again...
Thanks for the replies... I'll post if that works or not and/or when Autometer replies w/ their suggestion.
Old 02-05-2006, 03:20 PM
DR'76
DR'76's Avatar
Either my soldering skills SUCK or the PCM is REALLY finicky about receiving a clean signal... I tried splicing (or "T"-ing) into the VSS wire to go into the "Sig" terminal of the Speedo and again, the tranny doesn't shift correctly.
I'm using "Silver-Bearing" solder (96% tin, 4% silver)...is there something better to use?
Thanks!
Old 02-05-2006, 03:38 PM
FD2BLK
FD2BLK's Avatar
Are you tapping into two wires or one off the tranny? looking at my Helms book it looks as if you have 2 wires for VSS off the tranny Yellow (VSS Ground or VSS Low depending on where it is refenced) and PPl (VSS Signal or VSS high). On the stock C4 it goes from the VSS and splits to the SRC (Selective Ride Controll) and the ECM. I would think thta would indicate that with proper impedance you should be able to tap a second source (Your gauges) without a problem. I don't know but somthing to think about is that the VSS ground may be a data return signal and may not like a chassis ground attached. So if you are only tapping one wire look at the Autometer directions and see if they have a signal called VSS return or somthing similar.
Old 02-05-2006, 06:40 PM
Hooked on Vettes
I was looking at this site http://www.customclassictrucks.com/howto/23679/
Their Autometer Speedometer has inputs for a sine wave or square wave signal.
If yours also has two inputs are you connecting the Yellow wire to the sine wave input?
The solder you used should be no problem.
Autometers web-site is useless.
Old 02-05-2006, 10:49 PM
DR'76
DR'76's Avatar
FD2BLK:Which year Helms manual are you looking at? I don't see any "high" or "low" references in my '95 manual. (just for clarification, the Helms manual is the Service Manual, correct? I don't see "Helms" anywhere in my Service Manual, so want to be sure).
Anyway, looking at the four (4) PCM Connector figures, "VSS" is referenced in 3 of the wire descriptions: Pin A31 (VSS Ground - circuit 401, purple), Pin A32 (VSS Signal - circuit 400, yellow) and B8 (VSS OUTPUT - circuit 817, dark green w/ white)
I first tried the VSS OUTPUT wire to the "Sig" terminal in back of the Speedo, but got no response from the speedo. Then I cut the VSS SIGNAL wire and connected that to "Sig", then from the "Out" terminal went back to the PCM (So the path went FROM the VSS on the tranny, TO the "Sig" of the speedo, then from the "Out" of the speedo back to the PCM) This got the speedo functioning for a while, then had tranny shifting problems. My latest test was to just "T" into the VSS SIGNAL wire and go to "Sig" on the Speedo (nothing connected to "Out"). This also caused tranny shifting problems.
Hooked: No, my Speedo just has the "Sig" terminal. The directions supplied w/ the speedo show that either SINE or SQUARE wave would connect to that terminal and also has this notation:
"NOTE: This speedometer provides an output (OUT) terminal that can be used with late model vehicle installations using the existing VSS. In these installations, the VSS signal wire should be connected to the SIG terminal of the speedometer only. The OUT terminal should be connected to where the VSS output was originally wired. This will provide a buffered VSS signal to the PCM/computer in the vehicle."
It seems so simple
Old 02-05-2006, 11:10 PM
FD2BLK
FD2BLK's Avatar
Yes they are the helms book's, book two. It is a 1994 service Manual section "8A-33-0Electrical Diagnosis". You have to look at the selective ride control (SRC) and see where it T's into the VSS. THe .35 Yel (Pin A on the VSS/ A32 ECM) is the vehicle speed high to the SRC C15 and the .35 PPl (pin B on the VSS/ A32 ECM) is Vehicle speed low on the SRC D8. THis is what makes me think that the VSS ground is not actauly a ground but perhaps a return (.35 yel). One other thing that may help is looking at it it looks as if the ECM out goes through the CCM before it gets to the speedo. Just one more thing i find interesting is that both teh radio head and Cruise controll have notes not to stick a multi meter on them to mesure resistance, this usaly indicates a mosfet and it will get smoked if checked, is it posible that the auto meter is the same?
Old 02-05-2006, 11:13 PM
FD2BLK
FD2BLK's Avatar
"[B
NOTE:[/B] This speedometer provides an output (OUT) terminal that can be used with late model vehicle installations using the existing VSS. In these installations, the VSS signal wire should be connected to the SIG terminal of the speedometer only. The OUT terminal should be connected to where the VSS output was originally wired. This will provide a buffered VSS signal to the PCM/computer in the vehicle."
It seems so simple
This sounds as if you are not suposed to splice into it at all but rather cut it and connect the VSS side into the speedo and use the Out terminal and connect it to the ECM, is this how you have it connected? If you have it spliced it could be causing the load to the ECM I was refering to.
Somthing like this I would think would be the correct way
VSS------>(Speedo-->Out terminal)------>ECM
Rather then this
VSS-------->ECM and Speedo
Old 02-05-2006, 11:37 PM
ninetyfivevette
The A4 trans speed sensor outputs a sine wave, the ZF6 outputs a square wave, just FYI. I should also mention I can only speak for the 4L60E, I don't know about the 700R4...
To Autometer Speedo hook-up w/ LT1
Old 02-06-2006, 12:01 AM
DR'76
DR'76's Avatar
Yes, that's how it was connected when it "briefly" worked and then gave me the shifting problems (I also had it connected the other way, but that too gave me shifting problems. I am not sure if the speedo worked in that configuration, as I immediately stopped the vehicle and bypassed the speedo to drive back home...the speedo will not function until it goes thru a calibration process, which I was unable to do)
I think having a "hybrid" is going to make this more complicated than it should be BUT, I have a '76 Vette w/ only a '95 PCM, so I don't have any SRC, CCM, traction control, cruise control or any of the modern-day "options".
I now see where you referenced the "hi" and "low", but that's in the SRC (which I don't have) so not sure if that will come into play??? I do see on page 8A-33-3 (in the 95 book) where it discusses the fuctions of the VSS. It states that the VSS does produce a SINE wave (thank you "ninetyfive" for also pointing that out), THEN it gets amplified and converted to a SQUARE wave by the PCM which would then send this SQUARE wave out thru "B8" (or circuit 817) to such things as the SRC, Cruise Control Module, CCM, and Radio Control Head (all things I DON'T have). So (as you stated) it must go thru the CCM before getting to the speedometer, and don't know what happens to the signal inside the CCM...???
Maybe Autometer will reply and be able to make sense out of this...
Thanks to all for the replies...it's definitely been a learning experience!
OK, it's midnight here...MUST sleep!
Old 02-06-2006, 12:35 AM
FD2BLK
FD2BLK's Avatar
You should not need any of the devices in a C4 so that won't be a problem, the F-body does not have CCM, radio head or even the SRC as far as I know. The only reason I even mentioned the SRC is the fact they do refer to the same signals by differnt names leading to the posibility of the ground not being a hard ground but mabey a signal return. I think you have done everything correct and in reading your post are on the right path. At this point you realy do need feedback from Auto meter. Good luck and keep us posted.
Old 02-06-2006, 11:25 AM
jburnett
jburnett's Avatar
Well...I'm sorta doing the same thing... Just installed a LS1/4L60E into a '96 Caprice 9C1 (copcar); also installed a full Auto Meter guage cluster in place of the digi-dash. On the LS computers they have a 4k pulse coming off of the ECU to the speedo...I just connected that to the "Sig" on the speedo and left the "out" unplugged...Works perfectly. I should mention this IS an aftermarket wiring harness, though.
-Jeb
Quick Reply: Autometer Speedo hook-up w/ LT1
