Where is my Ignition Control Module ???
Cruising
Where is the ignition control module located on my 93 LT1, and is there any test for this item to see if it bad??
I'm just getting back to work on the car now after it quit on me Monday.
St. Jude Donor '05-'06
It sits above the coil on the front of the pass side head.2 screws hold it to a plate.You can take it to a part store like autozone to get it checked.Make sure they heat it up enough as most problems with them are when hot.There is thermal paste on the back of it make sure you use it and do not remove it or the module will cook.It uses the bracket as a heat sink.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Check your Helms manual. I had a problem with my 84 and the manual has a step by step process to check the module.
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't forget to check your coil, too. When my coil tanked on me two years ago, it took the ICM with it, resulting in a crank, no-start condition.
