A/C blows through Defroster/bottom vents only....
Thank you very much I did what you said I took off the tee fitting a look I was burnt
There is a "T" fitting under the passenger side fuel rail covers. This controls the vacuum operation of the vents. Since it lays on the intake manifold it is prone to melting. It looks like a little tiny fuel filter- only black and plastic. This may be your problem before you start ripping apart your dash.
Hope this helps,
chris
Hope this helps,
chris
The following 3 users liked this post by Cliff Harris:
vacuum hose meltdown
Hope this helps,
chris
Hope this helps,
chris
Jack
Fuel Rail Covers
Hope this helps,
chris
Hope this helps,
chris
would you know a part number?
I am sorry, but I just assume if the part melted, then the entire controller unit is useless, thus you would look for a salvage replacement from a scrap yard for entire unit. That said if only that multi-tap connector is melted, I am at loss as to how to "rebuild".
Jack
Jack
part number ( according to dorman)
Blue 260 is right on. 5 dollar part. Comes up as a different part number. Easy to replace. Air is blowing out all vents. Thanks Blue
There is a "T" fitting under the passenger side fuel rail covers. This controls the vacuum operation of the vents. Since it lays on the intake manifold it is prone to melting. It looks like a little tiny fuel filter- only black and plastic. This may be your problem before you start ripping apart your dash. 88lo
Hope this helps,
chris
Hope this helps,
chris
http://www.misterpeachy.com/VettePic...heck_Valve.JPG
