fuel pump relay location
Could someone tell me where the fuel pump relay is located on a 1990 I looked in the chiltons book and it showed it being on the firewall of the passangers side but i couldnt find it, also could you try to describe what it looks like to me.
thanks , mike
thanks , mike
Look next to the windsheild wiper motor on the drivers side. If it's a standard trans there will be two (one for the trans and one for the fuel pump, but the same sensor #)
and if you pull it-check the wiring going into it-the insulation shrinks and can cause bare wires to come in contact with one another-you know what happens then??? fuse-or eventual fire.
i was looking for it under the passanger kick panel and all i saw that looked something like a relay were 5 black squares that pull out. does that sound like them or are these something else.
skipmeister (12-15-2018)
