1.6 RR's....
1.6 RR's....
I am looking to purchase some 1.6 RR's and would like to know what all I need to make the swap.
I have searched but there is not a definate parts list. Any help appreciated.
93 LT1....
93 LT1....
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by KNCRSR5R
I was thinking Bee Hives....God or Bad Idea??
Also....how much more RPM will I gain?
Originally Posted by Corvette Kid NC
Not a bad idea at all. With the stock cam, I'd recommend the 26915 Comp Cams springs or check over in the C5 Parts F/S section for some '02-'04 LS6 take-offs.
Retainers? Will stockers work with these? Dont think I need teh TI ones...
787-16 Retainers
26915-16 Bee Hives
Rockers Arms... Chris, I see you have Pro Mags...I know yours is built more than mine...so would Mag's be ok....Pro's / Con's?
26915-16 Bee Hives
Pros:
Strong
Long life
Lighter than most aluminum rockers
More compact
Rebuildable if ever needed
Cons:
Uh......
Strong
Long life
More compact
Cons:
Uh......
im not familiar with all those spring pressures regarding z06 and c5 beehives. but the LT4 springs were desgned stronger for the higher redline. Id get replacement springs for the lt1 or a beehive if available in that pressure. If not id reccomend lt4s but not stronger. any extra spring pressure is just going to eat hp.
I did 1.6rrs on my 93 like 6 years ago with new lt1 springs, new pushrods, crane ignition. plugs/wires and march pulleys.. and it was a HUGE difference my mph went from 106 - 110 probably not only because if the increased hp but because it would pull so cleanly to redline.
1.6 RR's
Don't mean to buck the wisdom of the guys that advocate changing the springs, but I've gotten along just fine with the stock springs after adding Crane Gold 1.6 RR's on a basically stock '95 LT1 coupe. Maybe I'm living on borrowed time? Usually shift at 5500, but it runs to 6000 with no problems. I've accumulated probably 5000 miles with quite a few full throttle runs since the change without a glitch. One of the better bang for the buck mods out there.
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
Cam timing/overlap determines the rpm range where power is made. Lift determines how much power.
That's my story and I'm stickin' to it....
Larry
code5coupe
