What is a Quad driver?
Old 04-06-2006, 12:35 PM
quickcat
quickcat's Avatar
Default What is a Quad driver?
Can anyone explain to me what a Quad Driver code is?
Old 04-06-2006, 01:13 PM
Tom Piper
Tom Piper's Avatar
The Quad Drivers are part of the ECM in a '92.
They are not serviced separately from the ECM.
These drivers are essentially electronic amplifiers designed to be able to drive certain loads.
Tom Piper
Old 04-06-2006, 01:55 PM
OldCorvetteFan
OldCorvetteFan's Avatar
Default Quad Driver
Here's a link to some general information about quad drivers ...
http://www.onsemi.com/pub/Collateral/NCV7601-D.PDF
Steven
Old 04-06-2006, 01:59 PM
VenkmanP
VenkmanP's Avatar
The "quad" just means there are four in one IC.
Old 04-06-2006, 02:02 PM
quickcat
quickcat's Avatar
If I am getting a Quad Driver code would that indicate an ECM failure or is there a way to repair it.
Old 04-06-2006, 02:04 PM
quickcat
quickcat's Avatar
That's what I needed. I am going to have to crack her open and take a look.
Old 04-06-2006, 02:07 PM
VenkmanP
VenkmanP's Avatar
See what the shop manual says. My guess would be yes it means you need to replace the ECM.
Old 04-06-2006, 02:12 PM
ittlfly
ittlfly's Avatar
There are several quad drivers in a 92 ECM with separate default codes. Each one is responsible for sensing several functions ie: canister purge etc. If a problem appears in one of its sensed items, it will throw a code. You need to read and follow your FSM for flow chart for the code that the ECM is throwing. There is a strong possibility that there is a problem with one of the items that the quad driver is sensing rather than a bad ECM. Hope that makes sense.
Randy93
Randy93's Avatar
St. Jude Donor '06
My 93 got a code 28, then a 26, quad driver 3 & 1. You have to replace the ECM and trace down which sensor is sending a bad signal or is shorted. They are called quad drivers, because each one monitors 4 sensors. I had bad wiring to 2 sensors, hence the 2 codes.
VR'92
VR'92's Avatar
Location: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Getting a Quad Driver code does not mean the ECM is failing. I could just be the system that the QDM controls is failing. Most likley it is not an ECM failure. You need to get a service manual and look up the code.
Old 04-06-2006, 02:14 PM
quickcat
quickcat's Avatar
I am expecting my service manual to arrive today. I just got the car Friday.
Old 04-06-2006, 02:17 PM
ittlfly
ittlfly's Avatar
What code is being thrown?
Old 04-06-2006, 02:33 PM
RacerX70CC
RacerX70CC's Avatar
QDM (quad driver module) faults are typically the result of one of the controlled circuits failing, which in a lot of cases does smoke the QDM in the ECM. Typical failures include solenoids shorting out, or a short to ground on the solonoid's circuit, which of course will kill the QDM. The best way to fix this is to have a factory service manual, with the appropriate high-impedence DVOM (digital volt/ohm meter) to properly diagnose the circuit in question before destroying a new ECM. This isn't a case of "throw an ECM at it" to fix it.
YMMV
Old 04-06-2006, 03:06 PM
quickcat
quickcat's Avatar
28 Quad Driver 3
Old 04-06-2006, 03:38 PM
ittlfly
ittlfly's Avatar
That driver supplies the ground for both fan relays and the A/C clutch control relay. Check to see that these items are working.
Old 04-06-2006, 05:08 PM
quickcat
quickcat's Avatar
They seem to be working fine, but I will do a more accurate test this afternoon.
Old 04-06-2006, 05:57 PM
93 ragtop
93 ragtop's Avatar
I installed 2 switches to turn on my fans. If they are set to on, I get a quad driver fault when scanning. Turn it off and the fault goes away.
To What is a Quad driver?
Old 04-07-2006, 09:50 AM
VR'92
VR'92's Avatar
St. Jude Donor '03
28 Quad Driver 3
Have you removed any EGR/AIR equipment? This code will set with the removal of some of these items. Ask me how I know this?
Old 04-08-2006, 12:53 AM
mstock
mstock's Avatar
Default Ok
Tell us how you know this
Old 08-26-2013, 04:44 AM
orenkrief
orenkrief's Avatar
how do you know this????? i have the same code no egr valve and car dies after a 10 min drive
Quick Reply: What is a Quad driver?
