Heat shield for starter or solenoid?
Old 08-19-2001, 01:20 PM
robblk90
robblk90's Avatar
Default Heat shield for starter or solenoid?
I have a very bad heat soak problem with my starter. Should I get a heat shield for the starter or will a shield just for the solenoid work. I will have to order the one for the starter but I can get the one for the solenoid at the local parts house for about $3. I want to pull the starter only once so any help would appreciated.
Old 08-19-2001, 05:52 PM
ConeKLR
ConeKLR's Avatar
Cruise-In II Veteran
Default Re: Heat shield for starter or solenoid? (robblk90)
Heat shield blanket will work fine. did thi son my 91, no more heat soak problem after that. $30.00 bucks from Summit racing or local speed shop.
Quick Reply: Heat shield for starter or solenoid?
