Can a Torque Converter Be Repaired?(Bolt Holes)
Im helping a friend with his Vette and one of the torque converter holes is severly screwed up...the former owner/person that worked on it stripped the bolt threads and did a band aid fix to bolt the TC back onto the flywheel.
The tap they used snapped off inside the TC bolt thread hole when it was getting rethreaded and they tried to drill it out but drilled a bit sideways into the hole.So basically you cant just retap the threads.Its pretty bad out of whack.Makes alot of noise to drive the car like this with it banging since the bolt is missing.
We want to know if its feasible to get that hole welded shut and then redrilled and tapped again.Is it doable by a good welder?
Dont want to spend a fortune for another TC due to a messed up bolt hole.I pulled the TC out of the car and giving it a look over.Wish JB weld could be used but wouldnt dare use it in a place like that!
I don't see why not, I would think either the way you described or putting a new piece on it (obviously by a competent fabricator /welder).
I have had the rear hub on converters rewelded. Some of the early 9" converters I had would develop a leak at the hub and I had them welded with no issues.
Originally Posted by mseven
I don't see why not I have had the rear hub on converters rewelded. Some of the early 9" converters I had would develop a leak at the hub and I had them welded with no issues.
Originally Posted by Bill's86Coupe
Thanks,thats what I thought...Better find a machine shop that WILL touch it...a few places I spoke to said it cant be done and the weld would break off from the engines torque or etc...I think they just didnt want to be liable for any failures from their weldings...these days alot of places dont seem to want to do stuff like that no more,but sell you new parts.
I would imagine you probably have some real fabricators around your neck of the woods. Those are the kind of guys that would have a little more practical application, and have dealt with this kind of stuff.
If it is worth the trouble it could be drilled out and helicoiled. If the hole is too big for a helicoil, it can be sleeved with a piece of threaded rod, and re drilled to size. I have watched my machinest do it on rare stuff that cannot be easily replaced. Torque converters are somewhat cheap, if stock type. I have a connection for high quailty stuff. Stock( low buck) or high dollar 10 inch stuff. I built 2 transmissions recently that went to Europe. I used this company for the converters.
Thanks for all the replies...I dont think this converter is a GM unit,it looks smaller and appears to be aftermarket...isnt a name label or anything on there...Ill have to ask the guy who owns the car if its an aftermarket unit,the conversation never came up when removing it.
Hole is too big for a heli coil,maybe the threaded rod may do the trick...I may have found a machine shop nearby that can fix it...will be a few days before I know for sure.
