Is there a 16" draglite or prostar available?
I am looking for some draglites or pro stars for the rear of 1991. I would like to get a 16 inch wheel so I don't have to grind the caliper, but the only 16 inch wheel I can find is a draglite that is only 7 inches wide.
Is there an option for a 10 inch wide, 16 inch diameter, light weight wheel that is the proper back spacing for the C4?
Center Line has this...
http://www.centerlinewheels.com/whee...lt&data=5-4.75
They're not Weld, but Center Line does offer 16 and 17 inch wheels in AutoDrag III.
Thanks again.
Originally Posted by Vic'89
Grinding the calipers is not that big of a deal.
I run the 15x10 Weld drag lites with 7.5" backspacing.
The 15" rim gives you better tire choices.
Vic
Vic
Originally Posted by neat
Awesome! Thanks a bunch man, they are pretty proud of them at $272 each, but that would be better than grinding my calipers.
Thanks again.
Thanks again.
Nicole at Center Line knows her stuff, too...
