Did I F up?
Did I F up?
Ok, this weekend I messed with the TB, the IAC and the distributer. I cleaned up the TB and the IAC also made sure it was in adjustment and I took off and replaced the distributer.
Problem is this, car drove fine this morning to work, on the way home it was fine for the first 5 mins, after that it started acting up...misfires, sputtering...the works. 2 mins latter it gets even worse so much to the point I was coasting and could not get it to go once in gear. I then started to smell something like a burning smell (the exhaust) in the car...then the interior started to fill with smoke and this whole time I hear the exhaust makeing a god awful noise almost like its dragging. So I had to stop the first chance I get I open the hood and the only thing I could find wrong was I had forgot to hook up the hose running from the TB to the valve cover. After a few mins I started it back up and it ran rough for the 1 min drive home. Any ideas on what is the problem and how I can fix this? TIA (I am not driving the vette until its fixed)
the hose that goes to ur TB was a vacuum hose for the valve cover, correct? that disconnected would cause a nasty vacuum leak. that can cause overheating in the cyl and make ur headers glow from heat! that could be the smoke cause. the timing may have sounded like it was off, but i bet it was the comp trying to adjust for the heat and possible knock. check ur plugs, if the are nice and white, good chance it was that hose....
Prior owner did the hack job and I am thinking of replacing the unit and that plug just to be on the safe side. Thanks CC. Merlot thanks for the info..I will pull a plug tonight and check it out. I did not really think about it but that leak was more serious then I thought. If my plugs are white do I need to replace them? I am also going to check for wire damage as there was alot of smoke. Any other damage that I should be looking for? Thanks guys, your a HUGE help! I dunno what I would do without your help...well yeah I do, pay a mechanic a obsurd ammount of money to tell me what you guys do...lol. Again, thanks
This is the problem.
I reconnected the hose of course and me and a buddy pulled some stuff out checking for bad connections and we found/fixed one so we then started the car up and it purred at a perfect 930 RPMs for about 5 mins. Then we started wiggleing wires and as soon as I touched that burned up mess the car stumbled and shut off. I then could not start the car until I wiggled those wires some more. I am going to get to the junk yard and find me a new connector tomorrow until then I am most likely going to drive the vette like it is as my wife does need the other car. So a BIG thankyou to all of you who gave imput!
