Which 3/4 hose is the heater inlet hose?
Old 05-23-2006, 07:44 PM
boonie
boonie's Avatar
Default Which 3/4 hose is the heater inlet hose?
There are 2, 3/4 inch hoses connected to my 93 water pump, i need to indenify which hose is the water heater inlet hose so that i can properly install my back flush kit,
dose anyone know which of thses 2 hoses are the water inlet hose? i think it's the hose that has 3/4 T fitting that connects a 3/4 hose to the throttle body coolant outlet thats found on the 92-95 LT1 engines. correct?
your answers will be appericated.
thanks boonie
Old 05-23-2006, 08:01 PM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
On the L98, the heater inlet is the one coming off the TB. But since the LT1 is reverse flow, it might be the other one.
I don't think inlet/outlet matter though for flushing. As far as I know there are no check valves or solenoid valves on the heater circuit.
Old 05-23-2006, 09:11 PM
Corvette Kid
Large Impressive Member
Support Corvetteforum!
Corvette Kid's Avatar
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
See this
To Which 3/4 hose is the heater inlet hose?
Quick Reply: Which 3/4 hose is the heater inlet hose?
