Direct Port on a Superram
1 Post
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
Has anybody here actually done it? I'm thinking the runners are too thin and I'll need to weld a boss on them for more meat before I drill. I remember seeing some bungs welded on somebody's intake, but I don't think the nozzle would have enough length to get the orifice in far enough combining the thickness of the bung and the runner.
1 Post
'23-'24
They won't fit. There's just not enough room between the fuel rails and the plenum.
Location: ...tearing up the highways, one state at a time™®©
Received 2,102 Likes
11.3 on motor, 10.2 on NOS
Originally Posted by *89x2*
I know it was done to a freinds LPE 406 car - unless the castings have changed since the 1990's, it worked for him
Here is his 1991 Corvette, built by Lingenfelter in 1991,maybe early 1992
I bought a set that were drilled and tapped for fogger nozzles. he had some material welded on the inside and the outside.
He also had the runners extrude honed before the welding. I went ahead and removed the inside weld since it looked like it was going against flow. I also smoothed out the outside weld and polished the runners.
I never got around to installing the nozzles back in it, so I put allen screws in it to cap it, then I used a dremel and smoothed those out as well.
I dont have any pics handy, and since I moved, it will be a while till I do. I have the whole top end ripped apart still, so maybe in time I will get around to it.
these are the only photo's of the outside I have, and that is by random chance.
in these pics you can barely tell what he had welded on to them, but maybe it will give you some ideas.
1 Post
'23-'24
Thanks 89x2, those are good pics although I think it can be done a little cleaner
Bill, it was your car I remembered the pics of. Are those bungs that were welded in or did somebody weld in a boss and then tap it? It's hard to tell any detail from the pics.
No bungs on the teal car - no problems - I believe they were tapped while at LPE???
