SLP Cold-Air Induction System
I have a stock 92 LT1 and want to keep it close to stock (no changes to the internal engine). Has anyone intalled a SLP Cold-Air Induction System in their C4 ? Will it provide better performance ?
Received 1,400 Likes
The CLAW is not a true cold-air setup, it draws air from the same place as the stock setup and the surface area of the 3 filters is approx. the same as the stock filter. You'd get the same performance by cutting open the stock air lid.
It looks good, sounds good, but does little.
Location: One day you're a Comet...the next day you're dust... Arkansas
First advice I got after joining was to open up the stock airbox lid and go to K&N. When I opened my filter box it had the original filthy AC filter in it. (47K miles). I cut opening out and flared out the top of the lid to catch max air. Man what a difference in sound and seat of the pants kick. Finally a cheap mod that worked!
I installed a cold ram air by cutting a hole where the front license plate was. This included a K&N air filter. I definitenly noticed better gas mileage but the SOP is the same, maybe better.
