digital dash problem
climate control problem-digital dash problem
DIGITAL DASH FIXED... THANKS EVERYONE... IS THERE A SIMILIAR FIX FOR THE CLIMATE CONTROL. IT IS DISPLAYING SIMILIAR PROBLEMS AS MY DASH... THAT IS RANDOM FLASHING... BUT IT GOES AWAY WHEN I HIT THE OFF BUTTON.
I must have a loose connection and I am going to be taking my interior apart soon to try to fix it.. here is what is going on.
The entire digital display starts flashing with no ryhme or reason to it.... but when I tap the lower pad under the dash it goes back to normal... is there a switch there or a connection..
Just curious what your guys thoughts are before I start disassembling and looking around
HH
HH
Last edited by lawcorvette; 08-01-2006 at 01:52 PM. Reason: fixed dash but have similiar problem with climate control
Hi.
I have an 85 4+3 and the digital dash is the same( at least the problems and the repair.
I send you the address to a very nice page where you can see how to repair your dash. I had also a flashing dash but when there was no light the three lights on the bottom of the dash (high beam and directional lights) were ighting up.
Address: http://www.batee.com/corvette/dcrg/
Good luck
Good luck
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
My only suggestion is to be very careful when reassembling the LCD stack.
If you hear a crunch when tightening the LCD screws, You've broken a guage.
Thats about a 100 bucks to replace each unit.
If it is the backlight lamps that are intermittent here is my standard answer: The cluster has two circuit boards that plug together with a single row of pins on the front board into a socket on the rear board. The end pin closest to the center of the circuit board carries the lamp current and an age relaxed spring on this pin and the lamp current through it causes enough heat to unsolder the pin causing an intermittent connection. A permanent cure is to solder a short piece of insulated hookup wire from the pin to the socket. Resoldering the pin will not fix this problem. I did this about 8 years ago and have had no trouble since and I drive my 87 everyday.
thanks guys.
your description is exactly is real similar to what I have going on...
"I had also a flashing dash but when there was no light the three lights on the bottom of the dash (high beam and directional lights) were lighting up."
In your case was it a bad ground to the body or did you have to take the whole unit apart and resodder. I am a little worried about trying to sodder connections. When I look into it more, I guess I will know. I am working on the car in the next weekend
HH
HH
That Worked Great
Thanks everyone... resoldered the connection between the boards and just like new.
NOW- does anyone know how to fix the climate control. Is there a similiar fix?
HH
HH
Remove the climate control head from the dash. Get some electrical contact cleaner spray and some Q tips. Spray the Q tip with contact cleaner and wipe all the small male pins on the socket in the control head. Pull on the tabs at the rear of the control head to release the circuit board in the control head, pull the circuit board out and use the Q tip on the circuit board fingers. Re-insert the circuit board and re-install the control head.
