What throttle cable to use for carbed C4?
i used factory on my `90 with the jegs adapter plate. here are some pics. the motor pics start around " pool 56 ".http://www1.snapfish.com/thumbnailsh...74/t_=34977574
Originally Posted by 94-6spd
I may take off the tpi and carb it. What throttle cable did you carb guys use?
Only have to fab a bracket or mod your TPI one.
I'd love to "old school" (since I'm old) my 86. My biggest question is what affect does the carb have on emissions and economy? My other thought was something stand alone like holly projection. I saw a Corvette someone had carbed and replaced the dash with analog guages. I loved the look but haven't been able to find the picture again. Are the 86 transmissions computer run? Any affect on the performance of the transmission?
I you have an auto trans, the carb will require some brackets to restore the proper geometry to the tv system. A new cable is a good idea also. You will have to wire up the trans differently if you with to use lock up.
