What inline fuel pump to use on a TPI conversion?
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Converting a carb to a TPI, and thought it'd be easier to use an inline pump, as I have two gas tanks and a selector valve I'm pulling from. All the pumps I see in the catalog say not to use with fuel injection.
What GPH do I need for a stock TPI? 22#/hr x 8 = 176 #/hr = 30 GPH?
Would 55 do?
Then I need to figure out what size fuel lines to use. I'm thinking 5/16 supply and 1/4 return should work.
For the return lines I'll just use some type of double port valve so supply and return both switch over.
Would 55 do?
a ''friend of a friend'' went thru the pump jungle a couple months ago, trying to use an in-line...he didn't want any of the $500 catalog ones, found something for $140 and he's now on his third pump--no total faiure but they start to sound like a 6-71...an in-tank looks like the better way,two in your case... you'd even have limited back-up.
oem fuel lines are 3/8 supply and 5/16 return...my local napa now sells nylon similar to oem on my lt1 roaddie and price savings to use smaller are minimal.
Yeah, but how to bubba together a dual tank system with intank pumps? That sounds like a hassle. I now need a 4 port valve and a switching system, and two pumps! Yes $500 is a lot, but so is two pump setups, and it'd take who knows what kinda custom work to put them in the existing tanks.
How are the fuel injected trucks with dual tanks done?
[QUOTE=CentralCoaster]Yeah, but how to bubba together a dual tank system with intank pumps? That sounds like a hassle. I now need a 4 port valve and a switching system, and two pumps! Yes $500 is a lot, but so is two pump setups, and it'd take who knows what kinda custom work to put them in the existing tanks.
the fuel pump/gauge sender assy in a 94-96 B-body is a flanged, bolt-in arrangement, uses the same pump as a 92 vette lt1, and can be had from the j-y (locally) for $40, obviously you need two... cut a hole (abt 4'' IIRC) in the top of each tank, mod the height of the assy to match your tank (if nec)... tee the supply lines together (the pumps have integral check valves)...return line could use the elec diverter valve common on ford f-250 (ask your napa guy, was a $15 item altho its been a couple years since i bought one)--tie the tank vents together so that if the diverter valve fails, overflow will go to the secondary tank...one double pole on-off-on toggle switch will select tank and level sender at the same time (the diverter valve will only be power with one pump, it goes back to ''normal'' if no power)...maybe go big time and put in two new pumps @ $70 ea...if you mod the height of the assy, your gauge will read right at ''empty'' but higher readings will not be accurate.
Tank you!
I was looking for a pic of this diverter valve on rockauto, can't find it. or is this it?
http://198.208.187.182/servlet/com.e...cpartnbr=EP456
What's the difference between this and using a 3-port selector valve on the return?
Or, a single pump and a 6-port selector valve would work too.
These tanks may be difficult to work with, there's not much clearance above them for modification. And the 1st tank is under the passenger seat and pretty shallow.
It's going on a FJ40 land cruiser.
http://www.racetronix.com/Racetronix-TTA_Pump_Kit.html
CC, try this link. It may give you some ideas. I think they are supporting vendors also.
Originally Posted by CentralCoaster
Tank you!
i just checked a B-body pump/sender sleeping on my bench ...the piping/ elec will need 7/8'' above the top of the tank , the bottom of the pick-up is 9-3/4'' below the tank top, could be easily reduced by 2''...can e-mail you a pic if you want
T-Rex Makes an inline pump that wil free flow 70 GPH and should work for your application.
http://store.summitracing.com/partde...5&autoview=sku
