What is the most performance I can get for $300 in my stock C4 1994
Old 09-09-2001, 12:55 AM
Elmer
Elmer's Avatar
Default What is the most performance I can get for $300 in my stock C4 1994
I have a 1994 convertible automatic transmission. I installed a K&N air cleaner as the only modification. Should I use a chip change...What do others think is the best bang for $300 bucks. Thx Elmer in Dallas :cool:
Old 09-09-2001, 02:28 AM
GUMPA
GUMPA's Avatar
Default Re: What is the most performance I can get for $300 in my stock C4 1994 (Elmer)
Save just a little more money and put in 3:73 rear gears, your "slow" problems will be "over" :yesnod: :yesnod:
Old 09-09-2001, 11:06 AM
Crushinator
Crushinator's Avatar
Default Re: What is the most performance I can get for $300 in my stock C4 1994 (GUMPA)
I agree with GUMPA. Save a few more dollars and swap the gears. There's really no bolt on out there for $300 that's gonna make a noticeable difference.
Old 09-09-2001, 11:28 AM
Romeo Barrera
Romeo Barrera's Avatar
I'm not a fan of NOS, but it does have the most HP per buck.
Old 09-09-2001, 11:34 AM
wake
wake's Avatar
I'd say throw out the stock mufflers... When I replace mine, it was the biggest performance increase out of all my minor mods...
The stock set up is very restrictive for sound control...
Old 09-09-2001, 11:43 AM
Andy1983
Andy1983's Avatar
Default Re: What is the most performance I can get for $300 in my stock C4 1994 (wake)
Gears are really expensive.
Mid America sells 3.73 for $1299 for automatic and $1499 for manual.
just a "little" more than $300 :lol:
Basic stuff- Ram air, cat-back exhaust (will run you about $700-$1200 for whole system), and chip does help a little. Also, when you get a chance, look for a good ignition system.
Exhaust, Chip, and Ignition will EVENTUALLY pay for itself (depending on how much you drive), because they all give you better gas milleage. Although I don't think you could drive enough to get what you payed out of it, it is worth it for the sound/performance.
Just my .02,
Andy
Old 09-09-2001, 12:02 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
How about a case of beer with about $275.00 in change.
Old 09-09-2001, 12:04 PM
J Z06
J Z06's Avatar
Default Re: What is the most performance I can get for $300 in my stock C4 1994 (mackeyred96)
LOL, mack is going through withdrawls.. I'm sure He'd like to be RACING today...:D
Old 09-09-2001, 12:22 PM
Cisco Kid
Account disabled by request 24 Nov 2015
Cisco Kid's Avatar
I agree with the rest of the guys, changing your mufflers and your CAT to a high flow CAT (if that is an issue in TX. I am in CA.) and modifying your air filter will show some diffinite improvement for the amount of money you want to spend. Horsepower is not cheap so if you want it, unfortunately you will have to pay the price like the rest of us on these Vettes. :cheers:
Old 09-09-2001, 12:30 PM
vetteman9368
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default Re: What is the most performance I can get for $300 in my stock C4 1994 (Cisco Kid)
Gears Gears Gears. the gearset itself is about $300 plus installation. But if you have some mechanical knowledge you can do MOST of the labor yourself. I definently reccomend haveing someone set up the gears that knows what they are doing. then get your speedo corrected. it should be worth between 3-7 tenths depending on your stocl gear
To What is the most performance I can get for $300 in my stock C4 1994
Quick Reply: What is the most performance I can get for $300 in my stock C4 1994
