Rear Hatch Will Not Open
I have a 1994 Coupe. The rear hatch won't open even after replacing the relay and the solenoid, which I installed the same way the old one came out. When I push either the PKE, console or door hatch release button, I can hear the solenoid activating. The sound is loud and proud but the hatch won't open. Got milk? Uh, suggestions?
Try VERY CAREFULLY, lifting the hatch. The glass can stick to the hatch seal to the point the lift cylinders,especially if old, can't make the lift. If you hear the solenoid retract the latch should be clear so the hatch can open.
Double check the wire on the solenoid. Mine did this for a while where I could hear a "click" but it was the relay not the solenoid. I found the wire to the solenoid was loose. I crimped on a new connector and the problem went away.
1 Post
If you look carefully between the hatch shade retracted and the carpet below it you aill find a short piece of stainless steel whire pigtail. Grab this with a pliers and pull and the hatch should release. You should then be able to take off the trim that covers the lock and test the selenoid itself. The clicking sound is probably the relay for the lock that is under there.
The relay has been replaced.
The solenoid has been replaced. Before reinstalling it, I checked to see if it activated upon pressing one of the release buttons. It does. After I installed the solenoid, I could not open the hatch with the solenoid activating or with the manual release (using pliers).
I sense that the solenoid release mechanism is not engaging with the hatch latch; therefore, my quest is now opening the hatch another way. Otherwise I'll leave it as is. I must remember that my Vette is not my Dad's 1984 Chevy station wagon.
hatch
I have an 86 that happened to on the 4th of july (that's how i remembered it)
well I pulled the stainless wire, and popped the hatch, got a new solenoid, and 3 months later, it happened again.
This time, I went to the corvette junk yard and got one out of an 89, and it's still working.
since the chevy dealer wouldnt exchange it, I tore it apart
There's a slider link that if it isn't aligned just right, stick, and no solenoid will pull it open
get yours open, and try some grease and creative hammering
getting it open
How do I get the hatch open if pulling on the metal cord with pliers doesn't work?
Keep in mind that the relay and solenoid are working, but I think that coupeguy2001 hit on something about a misaligned slider link.
Get somebody to push down on the glass while you pull the wire. If there is an misalignment or other adjustment problem, that may freee up a binding condition.
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
The other method might include a variation of the above. While someone is activating the release, jiggle around with the screwdriver very carefully (as you have been doing), then alternating pushing down on the glass right at the latch point, as well as having someone pull on the cord. Also, see if you can wiggle the whole hatch glass a little bit, maybe using both hands. Again, this has worked on hoods on other cars if things are just a little out of line or need some very gentle persuasion.
No question the glass hatch is different than a good strong steel hood. Hope something works.
