coil ? on a LT1
Old 10-15-2006, 03:41 PM
Randy93
Randy93's Avatar
St. Jude Donor '06
Default coil ? on a LT1
I was showing a friend my car last night and the engine was running. Well right there where the coil is you could see a glow blink on on the right and then left and it did this the whole time. I just replaced my coil about a week ago, is this normal or did I get a bad coil?
The car has been running rough for about a year and I just can't seem to track down the problem.
Old 10-15-2006, 04:37 PM
Zepher
Zepher's Avatar
maybe the wires are bad, or you need to clean the head where the coil is bolted down.
Old 10-16-2006, 09:21 AM
pcolt94
pcolt94's Avatar
If you are talking about arking, you should not see any arking from the base of the coil to ground. Make sure your coil wire outer insulation is not breaking down and causing the ark. I know the coil is new, but make sure it is clean and dry of any moisture. Other than that, was your original coil doing the same?
Old 10-16-2006, 10:02 AM
Tom Piper
Tom Piper's Avatar
I've heard so many comments about the small arcing/glowing around the LT1 ignition coil, that I am starting to believe this is normal.
Tom Piper
Old 10-16-2006, 10:15 AM
runner140*
Support Corvetteforum!
runner140*'s Avatar
Tom Piper
Its NOT normal.....
Old 10-16-2006, 04:59 PM
Jerris
Jerris's Avatar
Sounds like you have a coil wire that is breaking down and building up enough resistance that the spark escapes. Try replacing the coil wire and see what happens.
On my LT1 there is no sparking around the coil.
Old 10-17-2006, 09:10 AM
Randy93
Randy93's Avatar
St. Jude Donor '06
I was afraid of that, I will check the coil wires this weekend.
Thanks eveyone!!
To coil ? on a LT1
Quick Reply: coil ? on a LT1
