Adjustable throttle position sensor?
Old 10-18-2006, 06:48 PM
Kool88vette
Kool88vette's Avatar
Default Adjustable throttle position sensor?
Has anyone tried one of these adjustable throttle position sensors/ Do they do anything? http://www.ecklers.com/product.asp?p...dept%5Fid=1268
Old 10-18-2006, 06:56 PM
CFI-EFI
CFI-EFI's Avatar
Your 1988 came with an adjustable TPS. Adjust it as per the instructions in your FSM (Factory Service Manual).
RACE ON!!!
Old 10-18-2006, 08:01 PM
Kool88vette
Thanks for the reply. I'm wondering if it's time to replace the tps. It is 18 years old. I get a faster acceleration at 3/4 throttle and an erratic idle. An adjustable is cheaper than an new OEM. I also think that because of all the mods an adjustable might be a good idea, I don't know anything about them. Has anyone used one?
Old 10-18-2006, 09:27 PM
CFI-EFI
CFI-EFI's Avatar
The "new OEM" TPS IS adjustable. Did you not understand my first post? Before you replace ANYTHING, test it. There is no point in replacing good, factory, OE parts, with questionable replacements. In fact there is no point in replacing good, functioning parts, at all.
RACE ON!!!
Old 10-18-2006, 09:36 PM
Kool88vette
Ok I'll test it first, thanks.
Old 10-18-2006, 09:41 PM
davemack
davemack's Avatar
CFI-EFI is right (he always is..). The TPS is always adjustable. The ecklers kit just includes a wiring harness that makes it easier to adjust to the correct output voltage by providing clips that can attach to the probes on your DMM.
Save your $; or, if they're really burning a hole in your pocket, you can always contribute to the save the "85 w/irregular idle" repair fund..rofl:
Old 10-18-2006, 09:50 PM
Yellow2015
Yellow2015's Avatar
As stated, the TPS is already adjustable. About all that ecklers thing is good for is providing a place to connect your meter. And they already sell that in their tools section.
Your idle problem could be as simple as needing a good TB cleaning along with removing the IAC motor and cleaning it also.
Old 10-18-2006, 09:58 PM
lefoy84
lefoy84's Avatar
Don't take it personally, he's usually right but tact is not his long suite.
To Adjustable throttle position sensor?
Quick Reply: Adjustable throttle position sensor?
