wheel bearing noise?
Old 11-11-2006, 03:36 PM
larryfs
larryfs's Avatar
Default wheel bearing noise?
Is it possible for a wheel bearing to be tight, and still make a ton of noise on the highway ?
I have this strange growling noise, grinding noise from the rear left side.
it also can sound like a dull thud thud noise.
But the wheel bearing is tight......
Old 11-11-2006, 04:03 PM
scranage
Support Corvetteforum!
scranage's Avatar
Half shaft U-Joints?
Old 11-11-2006, 10:05 PM
89vert
89vert's Avatar
Old 11-19-2006, 02:02 PM
larryfs
larryfs's Avatar
I have the rear bearing out, and it seems quite on the bench. But you can see where all the grease leaked out of it.
It is normal for any of the grease to leak out past the seal, and be lying in the bottom of the aluminum spacer?
This is a bear of a job, and I'd hate to do it twice........
Old 11-19-2006, 02:58 PM
eschoendorff
eschoendorff's Avatar
St. Jude Donor '08
The bearing may seem quiet on the bench, but if the grease has come out, I'm afraid that you're looking at another wheel bearing. You said the bearing was tight - did you check it for play with the wheel on the car? That's when the play is most evident. Even a bad bearing can appear tight on the bench. My .02.
Old 11-19-2006, 06:52 PM
C4boy
C4boy's Avatar
100% with Esch.
I just did my fronts and the worst one was the bearing leaking grease. It had a very noticeable amount of play at the wheel when I put it on a lift. The other bearing only had a slight bit of play and is very difficult to feel with the bearing mounted in a vise. Check your axle u-joints, too. But the rumbling sound you're describing is the same problem I had.
Old 11-19-2006, 07:15 PM
larryfs
larryfs's Avatar
what brand of bearings did you get.
my bearing was TIGHT, in fact, ZERO play on the car.
but the rumbling noise was the tell tale sign......
Old 11-19-2006, 08:51 PM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The grease means it overheated from friction (or was overpacked with grease from the factory) or both.
Replace it.
To wheel bearing noise?
Quick Reply: wheel bearing noise?
