Pics of Melling potential disasters!!!!!
Old 01-02-2008, 10:08 PM
  #201
85vet
85vet's Avatar
Cruise-In V Veteran
Originally Posted by Calderone
i've just got my Melling pump
and now im scared !!!
maybe i've just got the BAD style pump !
is it no good for my L98 ?
im currently rebuilding it
and i dont want it to fail
if its really the bad one,which pump should i go with ?
thanx
here pics of my new never used pump
You can take a chance with it, but you should go with a Select pump instead. Stock is 10553.
Old 01-02-2008, 10:21 PM
  #202
jeffyc
jeffyc's Avatar
i went with the 10555 pump even though i didnt want to have anything to do with melling after this crap
Old 01-02-2008, 10:53 PM
  #203
Slalom4me
Slalom4me's Avatar
I've just got my Melling M55HV pump
and now I'm scared !!! Maybe
I've just got the BAD style pump !
From #145 (12/2006)
However, now I wonder if there are three levels
of castings: weak, intermediate and heavy.
I stopped by a local shop today and discussed this with the mgr.
He brought out an M55, M55HV and an M-Select 10555 for us to
look at. (These do not have equivalent dimensions, they happened
to be what he had available in the three models.)
The M55 clearly has the least material in the pump leg, the notch
created when the bolt hole was spot-faced was <= 3/16" wide.
The top of the leg where it joins the main cap is surfaced flat with
no pocket. The casting is light/medium gray in colour.
The M55HV is the same colour but the notch is wider. The top of
the leg has a pocket. The picture Midnight 85 posted above is
pretty much the same as the pump I looked at. The same warning
card is in the box.
The M-Select 10555 comes in different, black packaging. The casting
colour is much darker. The notch is wider than the M55HV. The
casting seemed beefier in the main body, too, with more rounded
corners and less casting flash. The top of the leg has a pocket.
The M55HV had more material in the leg than the M55, but it still
shipped with Melling's warning card.
If I was building an engine for performance use and had the luxury of
waiting, I would choose to exhange the M55HV for an appropriate
M-Select pump from Melling (or from one of their resellers.)
If an M55HV was installed in a completed car, I'd have to think about
my intended use of the vehicle and weigh the risks of failure against
the effort & expense of replacing the pump.
Old 01-02-2008, 11:09 PM
  #204
85vet
85vet's Avatar
Cruise-In V Veteran
From #145 (12/2006)
Hey - Happy New year!!!
I on the other hand, being conservative, would never let a potential failing POS melling standard pump in any small block.
jeffyc - DO not use a bolt to hold the pump on - USE A STUD/NUT.
Old 01-02-2008, 11:45 PM
  #205
Calderone
Calderone's Avatar
i think i will reuse my old pump
or maybe its worn out ????
i cant find a select pump on ebay
Old 01-03-2008, 12:48 AM
  #206
Calderone
Calderone's Avatar
i dont want to take the risk
so i think im buying
http://www.milodon.com/oil-system/oil-pumps.asp
but i dont know which one !!
or maybe the Melling # 10553 old style oil pump
or maybe reuse my old stock pump
what you think ?????????
Old 01-03-2008, 07:40 AM
  #207
85vet
85vet's Avatar
Cruise-In V Veteran
The milodon pump would be #18755 - but it looks like it has a sleeve in the bolt up area. If you want to be safe - go with the 10553 and use a stud to bolt it up.
Old 01-03-2008, 08:36 AM
  #208
Calderone
Calderone's Avatar
How's the stud thing ?
thanx
Old 01-03-2008, 09:01 AM
  #209
Slalom4me
Slalom4me's Avatar
... and use a stud to bolt it up.
thanx
Instead of using a bolt to retain the pump, install a stud.
ARP sells at least four styles suitable for the SBC: 230-7001 through
to 230-7004. Two have conventional hex nuts (SV & HV castings) and
two have 12 point nuts (SV & HV castings).
As for a source for M-Select pumps, forum supporter Jegs carries the line.
Old 01-03-2008, 09:30 AM
  #210
Calderone
Calderone's Avatar
yeah yeah,thanx but why its better to use a stud instead?
i think a stud difficult to "self unbolt" hehe ???
Old 01-03-2008, 01:25 PM
  #211
85vet
85vet's Avatar
Cruise-In V Veteran
The use of a stud exerts clamping force differently than a bolt. Also recommended by my builder.
Old 01-03-2008, 03:25 PM
  #212
Slalom4me
Slalom4me's Avatar
Thanks, but why is it better to use a stud instead?
Why?
The following is paraphrased from Chapter 5 - Bolt Specifics
"Carroll Smith's Nuts, Bolts Fasteners and Plumbing Handbook"
Motorbooks International
ISBN-10: 0879384069
$25 @ Amazon
In highly stressed applications, studs are preferable to bolts
for two reasons.
  • First, less of the force of tightening is used up in overcoming
    thread friction, so the desired level of residual stress can be
    more accurately approximated.
  • Second, residual stress in a stud is more evenly distributed
    than in a bolt.
For female threads in castings, studs are preferable to bolts where
frequent removal and installation of parts occurs. This is because
when studs are used, thread wear/damage occurs on the studs,
instead of on the threaded holes in the casting. Replacing a damaged
stud is easier and cheaper than repairing a threaded hole.
Note that studs are intended to be inserted finger-tight only, not
torqued into the hole. Theoretically, a Class 5B tap should be used
to form the female threads - this results in a slight interference
fit which helps prevent the stud from backing out when the nut
is removed. However, in practice where studs are used in holes
originally tapped for bolts, the application of Loctite will serve to
achieve the desired interference fit.
Old 01-03-2008, 03:55 PM
  #213
Calderone
Calderone's Avatar
Thanx ! Good explanation ! now its crystal clear for me
i found this on another board,Camaro related
and the same ...a guy broke his Melling pump in almost two !!!!
the new casting its really weak and i dont want to take the risk !
Look at this !!! :
Old 01-03-2008, 05:26 PM
  #214
Slalom4me
Slalom4me's Avatar
I found this on another board, Camaro related
and the same ...a guy broke his Melling pump in two !
The new casting it's really weak and I dont want to take the risk !
Look at this !!! :
When stating 'The new casting', it is important to distinguish between
the M-Select casting and the revised casting for the traditional pumps.
My vote is that the M-Select is the newest casting, while the revised
versions of the original castings are said to have been in production
since 04/05.
The pump shown above is not an M-Select. This pump has a narrow
gusset extending to the leg from the body and there is no pocket in the
flange mount where the oil exits into the rear main cap. The M-Select
casting is much heavier in the leg area and all versions I have seen
include a pocket in the flange.
Old 01-03-2008, 05:53 PM
  #215
Calderone
Calderone's Avatar
Yes i know is a regular pump
that's why we should go with a M-Select one
But ....now that you say...
maybe there is a "new version " of the M-Select too ???????
btw ....how many of you had problems with your oil pump ?
maybe its all hype
Old 01-03-2008, 06:51 PM
  #216
Slalom4me
Slalom4me's Avatar
maybe there is a "new version " of the M-Select too?
No, I am not saying there is an updated version of the M-Select.
You wrote "the new casting its really weak" and posted a picture of
what appears to be an M55. My understanding is that the M-Select
line is the newest series of pumps.
Chronologically
  1. Traditional Melling M55 & ect.
  2. 'Improved' lightweight Melling M55 & ect.
  3. M-Select 10553 & ect.
So far, the M-Select castings appear to be sturdy and a better
choice for performance use than the lightweight Melling M55 & ect.
Old 01-03-2008, 07:13 PM
  #217
Calderone
Calderone's Avatar
No,the M-Select line its not a new line from what i know
but i might be wrong
its something like Melling's performance series
To Pics of Melling potential disasters!!!!!
Old 01-03-2008, 08:04 PM
  #218
Slalom4me
Slalom4me's Avatar
From the Melling website
Welcome to the NEW Melling Select Performance Line of Engine Parts!
In 2006, our 60th year in business, we are re-inventing ourselves
and creating this new chapter in our history book.
The Melling Select Performance brand was conceived in November 2004
to better market our current performance oil pumps, camshafts, timing
components, valve train, and cylinder sleeves. We also have a goal to
further analyze the performance engine parts market, specifically
the “hobbyist street rodder” and the “weekend warrior racer” to
develop new and innovative engine parts for them.
The re-engineered M55 series pumps are said to have been released
in 04/05.
Old 01-03-2008, 08:10 PM
  #219
Calderone
Calderone's Avatar
i see...but i have a 07 melling pump
it says "MAY07" on the sticker and it has the thin casting too
i will need to get the M-select asap !
Old 01-04-2008, 02:10 PM
  #220
corvette90
corvette90's Avatar
hi
maybe also take a look at the bottom of page 10....
PM gears now in them.....
http://forums.corvetteforum.com/show...558337&page=10
regards
Quick Reply: Pics of Melling potential disasters!!!!!
