Pics of Melling potential disasters!!!!!
#161
I ordered a 10553 a few weeks ago and it was available same day at Summit.
I had some dowel issues recently resolved...
The 10553 with a canton pick-up fits great in the canton 240-T 7" road race pan. Here is a pic of the unit.
#163
M55hv
Guys,
I have 3 Melling M55HV pumps ready to go on customer engines , here is what they look like at the bolt flange.
Also I like using a stud to mount the pump anyway.
Note how much thicker the mounting casting is , and no bushing insert like on the cheap pump.also made in USA casting?
Desert
Desert
#164
the source I've been waiting on.
I have also purchased a 10552C - a heavy duty casting with anti-cavitation
grooves. It happens to have a slightly taller set of gears (to provide
10% more volume) so the body is taller overall. It also has a 3/4"
inlet with provisions for either press-in or bolt-on pickup. I'll provide
pictures eventually.
Meanwhile, this post keeps the thread open for a while longer.
#165
I talked with the melling rep at the Lordco trade show last week. He blames the fracture on wheel hop and solid motor mounts. He told me he knew who I was talking about.
If that's the case, then I have nothing to worry about.
I also looked at their billet pump, now that is nice !!
#166
Cruise-In V Veteran
BS on melling - I do not have wheel hop or solid motor mounts. Jese, maybe he is talking about my solid roller cam
Slalom4me, I have the same additional 10% pump. Had to have a pickup manufactured.
with 0-20 racing oil, engine warm, my pressure is 22 at idle, but hits 55 - 60 at full throttle.
#167
Cruise-In V Veteran
Guys,
Desert
Desert
if newer pumps, then there are multiple changes being made to these pumps.
#169
Guys,
Desert
Desert
Also, I was just looking at the box and it says "New Generation" M155HV
#173
Cruise-In V Veteran
http://s8.photobucket.com/albums/a26...53vsM10552.jpg
#174
It might work for me because the pickup was a little short anyway. I am going to cut off the matchbox and weld it to the bolt on pick up or just change the bottom plate. Will see when the time comes.
#175
they address this in this months hotrod readers letters in the back.. they said to become GM's supplier for the pumps that GM requested the change.. stock pump is not for solid motor mounts or hot engines.. they have another part number for those types of cars.. check it out www.hotrod.com or get this months issue..
#176
Cruise-In V Veteran
#177
#178
Today I got my Golen 383 short block ... I ordered it with a stock volume oil pump.
What I got is a M55HV and it looks like the strong casting ... do I definitely have a high volume pump?
If so, what is the best stock volume pump to buy?
Best wishes
Eike
Best wishes
Eike
#179
I would have to guess yes it is the weak casting. I ended up going with the Canton pan and pickup with the Melling Select 10555 which is the high volume pump. I had to raise the pickup just a bit by using a rubber hammer on the bracket. I've got good clearance and oil pressure is 65-70 on the road hot with an idle pressure of around 40 also hot. I'm using Mobil 1 10w30. Although Melling execs should be hung for doing this to the performance crowd I have to admit the select line is some nice equipment.
#180
oil pumps
What all that means is in my experience a High Volume/High Pressure oil pumps can suck a stock oil pan dry at 6000 Rpm , maybe less.
So unless you have a super BAD *** Race Motor I would stay away from the exotic super high pressure pumps , you don't need it.
I like high volume but not high pressure , just my .02
If you talk to any good engine builder who has an engine dyno , they will tell you just enough pressure to keep the oil film on the bearings any more pressure is wasted and can even take away Horsepower at high RPM's.
I would keep the pump you have just put a stock relief valve spring in it , its an easy swap.
that way it has high volume but not 60-80 PSI.
Desert
