Swap Out Ecu
12-18-2006, 09:53 AM
Swap Out Ecu
Can I use the ECU from a 1986 in a 1988 ?
I got a doner car and it had the ECU repaired.
12-18-2006, 09:56 AM
Quote:
Originally Posted by
TioVictor
Yes, but you need to check the bradcast code of the chip to make sure it is compatiable, or use the chip from your 86....
12-18-2006, 02:30 PM
mk842766
86-89 ECM's are compatable, just the broadcast code is different on the chips.
12-18-2006, 03:50 PM
Thanks.
How do I know if the chip is good? Or is it that it is ether good or dead?
