C4 Rear Suspension Dimensions
Old 01-24-2007, 03:59 PM
Black 82
Black 82's Avatar
Default C4 Rear Suspension Dimensions
I'm doing a conversion on my C3. Does anyone have, or know where I can get, the frame mounting dimensions for the rear trailing arms and batwing?
Old 01-24-2007, 05:07 PM
rocco16
rocco16's Avatar
Location: SCMR Rat Pack'r Charter Member..Great Bend KS
You can get the dimensions from a C4 chassis.
I know you were looking for numbers or a weblink....something quick and easy....but you should be prepared to devote some real effort to this project, and you might as well start right now.
Good luck and let us know how it goes.
Larry
code5coupe
Old 01-24-2007, 06:28 PM
Black 82
Black 82's Avatar
Thanks for the pep talk rocco.
I was hoping somebody had access to something like this...
http://abf-framedata.com/index.html
For $105 I might just buy it. But something tells me it won't have all the dims i need.
Anybody here work in a frame straightening shop with access to dimensional data?
Old 01-24-2007, 10:15 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm hoping you have success with the frame dimension info search.
I'm about 60% complete on my C4 suspension swap onto my spare '69 frame, but I've pretty much had to wing most of it. Finding dimensional information other than common alignment specs is almost non-existent.
Old 01-25-2007, 09:34 AM
Vetracr
Vetracr's Avatar
Check a GM C4 Corvette shop manual. The body repair section has the frame dims you may be looking for.
Larry
Old 01-25-2007, 10:16 AM
AGENT 86
AGENT 86's Avatar
You might find a couple of useful numbers here http://members.shaw.ca/agent86/Frame%20Dimensions.pdf
Old 01-25-2007, 11:19 AM
LT1inaMGB
LT1inaMGB's Avatar
I went to a frame straightening shop and asked the guys if I could make a copy of the '88 Corvette page and they let me. They even had a large format copy machine. Be friendly and tell what you want to use the info for and hope you find someone in a good mood. The detail on the car is great, it gives coordinates for all the suspension mounting and pickup points.
Jim
To C4 Rear Suspension Dimensions
Quick Reply: C4 Rear Suspension Dimensions
