Gaskets/Seals Needed for Hotcam install???
Okay guys I'm looking at installing a LT4 Hotcam in my stock LT4. Just the cam. What gaskets and/or seal will in need on hand? I'm thinking:
intake gaskets
valve cover gaskets
timing chain cover gasket
water pump gasket
What am I missing?
Thanks in advance,
David
intake gaskets
valve cover gaskets
water pump gasket
What am I missing?
Thanks in advance,
David
You might as well change the timing cover seals while you are at it, and there is a pretty good chance you'll damage the oil pan gasket.
The valve cover gaskets, if not leaking now can be reused.
